Subject: Is there a way to turn this option off in P7?
RnRWoman opened this issue on Oct 15, 2008 · 18 posts
RnRWoman posted Wed, 15 October 2008 at 9:48 PM
Hi all,
I'm working with the grouping tool in the hair room trying to make a stubble prop. Everytime I try to select anything, it shows up selected like this in a green outline (see attached picture.)  Is there any option to turn this feature off? It makes it hard to focus on close details when trying to work in the hair room especially.
Thanks in advance!
--R.
RnRWoman posted Wed, 15 October 2008 at 10:46 PM
Hmm, it says I have a reply in this thread but I don't see it. :-O
--R.
manoloz posted Wed, 15 October 2008 at 10:49 PM
Try a different display mode, like hidden wireframe?
still hooked to real life and enjoying the siesta!
Visit my blog! :D
Visit my portfolio! :D
RnRWoman posted Thu, 16 October 2008 at 2:44 AM
Okay, I'll have to try that. Thanks!
--R.
IsaoShi posted Thu, 16 October 2008 at 6:07 AM
There is an option to switch this off, but I'm at work and I can't remember it. Look under the Display menu for something like "Show selection outline...", and untick it. As I say, i can't remember exactly what the words are, but it's there!
Izi
"If I were a shadow, I know I wouldn't like to be half of what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki Murakami)
Doran posted Thu, 16 October 2008 at 11:16 AM
I tried everything under the display menu and nothing seemed to work. I don't think this can be turned off. I agree with RnRWoman, this is irritating.
Dizzi posted Thu, 16 October 2008 at 1:28 PM
Set "HILITE_BODY_PART" to 0 in the Poser.ini.
pjz99 posted Thu, 16 October 2008 at 2:11 PM
If you have access to practically any modeling application, you'll find that selecting polygons for this kind of purpose is MUCH MUCH EASIER.  Poser's Group Editor is terrible compared to pretty much any other tool.
My Freebies
IsaoShi posted Thu, 16 October 2008 at 2:40 PM
Quote - Set "HILITE_BODY_PART" to 0 in the Poser.ini.
Ah yes, that was it.. not on the menu at all, but in the .ini file. Sorry to have misled you.
RnRWoman posted Thu, 16 October 2008 at 2:42 PM
Quote - There is an option to switch this off, but I'm at work and I can't remember it. Look under the Display menu for something like "Show selection outline...", and untick it. As I say, i can't remember exactly what the words are, but it's there!
Izi
Thank you so much, I'll have to try that! :) I'll let you all know if it works.
--R.
RnRWoman posted Thu, 16 October 2008 at 2:44 PM
Quote - If you have access to practically any modeling application, you'll find that selecting polygons for this kind of purpose is MUCH MUCH EASIER.  Poser's Group Editor is terrible compared to pretty much any other tool.
I have ZBrush, CInema and Truespace. Will any of these do the same thing? I'm unfamilar with grouping in this way in other programs.
--R.
RnRWoman posted Thu, 16 October 2008 at 2:45 PM
Quote - I tried everything under the display menu and nothing seemed to work. I don't think this can be turned off. I agree with RnRWoman, this is irritating.
It is isn't it? Especially for those zoomed in shots when you're trying to get little tiny polygons selected. :P
--R.
Thanks for the suggestion! I'm going to try that now. :)
--R.
RnRWoman posted Thu, 16 October 2008 at 2:52 PM
Okay, I've ran into a problem. I can not find any "Poser.ini" file for Poser 7. I would think it wouldn't be stored in an other location... But is it by any chance stored somewhere else?
Thanks!
--R.
IsaoShi posted Thu, 16 October 2008 at 3:09 PM
It is stored in your user profile.
In Windows XP I think the path is:-
C:Documents and SettingsLocal SettingsApplication DataPoser 7Poser.ini
(But you already know about my memory).
In Mac OS X the file is:-
/Users//Library/Preferences/Poser 7/Poser Prefs
(I cheated and looked).
(edit) If you are in Windows and you can't see the Local Settings folder, you will need to tick "Show hidden files and folders" in your Folder Options. Or just type the full folder path into the address toolbar.
RnRWoman posted Thu, 16 October 2008 at 3:14 PM
Thank you so much!
I'm a Vista user, however your instructions still helped me find the directory.  For Vista, this is the directory you might want to look for it in: C: Users AppData Roaming Poser 7 Poser.ini. Hope that is helpful to any Vista users using Poser!
Thanks again! I'm going to see if that works now. :D
--R.
UPDATE: It works! Thanks to all who've helped me with this issue! I hope this thread is of help to others!
Doran posted Thu, 16 October 2008 at 8:33 PM
Yay! It worked! Thanks everyone :D
RnRWoman posted Fri, 17 October 2008 at 3:52 PM
Great!! I'm glad it worked for you too, Doran! I don't know about you, but it certainly makes Poser a lot faster when in the hair room. Now I can make dynamic hair more comfortably and Poser moves along a lot more smoothly. Thank you for your comments!
And thanks again to all who helped! :)
--R.
