Subject: Need Some Help
gandok opened this issue on Oct 16, 2008 · 4 posts
gandok posted Thu, 16 October 2008 at 5:20 PM
For some reason when I load certain objects (not all) in to Poser 7, they are coming up as if they are low rez (see the sample screen shot with the polygons on the figures clearly visible). I've used these objects in the past and have not seen this happen before. This issue does not come up when I load a custom morphed Aiko that I have saved off. I know from this that it doesn't happen on every character using the Aiko figure. There doesn't appear to be a pattern to when this occurs and when it doesn't (at least I don't see the pattern). This issue started happening in the last week. I'm not sure what may have caused this. I've searched around on different sites, and played around with the Poser's configuration, but have not found out how to correct this. I've updated my video drivers (NVidia 7800GTX if that helps). I've also reloaded Poser. Anyone have any suggestions why this is happening and what I can do to remedy it?
Thanks for the anticipated help.
bagginsbill posted Thu, 16 October 2008 at 5:53 PM
That's what meshes look like when the crease angle is too low. Check the crease angle - should be 80.
gandok posted Thu, 16 October 2008 at 5:59 PM
Thank you, bagginsbill!! Soon as I read your post, I recalled playing with that value a few days back. I guess my slow brain forgot to turn that setting back.
Thanks for your help.
bagginsbill posted Thu, 16 October 2008 at 6:18 PM
Yay!
