Forum: 3D Modeling
Subject: Help!!! Problems with long sleeves of a conf. dress for V4
chasmata opened this issue on Nov 03, 2008 · 4 posts
chasmata posted Mon, 03 November 2008 at 2:28 PM
Hi there, I need help... a little tip should do it...
I have made a dress for V4 with long wide sleeves. It works in Poser very well - but when I bend the arm of the V4 the sleeve "explodes" at the seam.
In the past I tried with the bones, I changed some polygones of the hand and forearm . But with this dress it doesn't work.  Has anybody an idea what I have to do? Is this a JCM problem like the elbows?
I have no idea after hours of testing and testing....
I put some extra bones in it - but it doesn't work really. All polygons are included - that's sure.
I made bones with a new donor in Poser.... the sleeves of the dress work now but I can see some visible "bones" back in the pose room. I can't delete them and they are visible after rendering.
The thing is:
When I have unselect the "bend" in the parameter options for the forearm, the hem of the sleeve is correct, it doesn't explode. But then poser split the groups and there is a small split between the forearms and the shoulder of the sleeve.
Can anybody help???.... this dress drives me crazy.....
markschum posted Mon, 03 November 2008 at 4:24 PM
Ideally the donor cr2 should go one body part beyond the clothing. So include neck and hands for a long sleeved shirt.  That makes sure that any bends caused by that extra body part are transmitted properly to the clothing.
Check the joint inclusion zone , and make sure it is large enough to include the clothing , this is very important for wide sleeves .
markschum posted Mon, 03 November 2008 at 6:09 PM
If you want to make a zip file and send your cr2 and the dress obj I could have a look at it for you.
my email is marks542004@yahoo.com , please ensure the subject line is complete. I cant do more than 4 meg or so  :( in a download
miste1982 posted Sat, 08 November 2008 at 4:33 AM
Here is how you fix your problem  http://www.philc.net/WW2_help.htm  ( at the bottom of the page start the video with that green t-shirt named " Joint Parameter " )
