Subject: Poser Pro Acting Sluggish
redtiger7 opened this issue on Nov 06, 2008 · 12 posts
redtiger7 posted Thu, 06 November 2008 at 2:28 PM
Working on a pic, nothing too expansive. V3 and M3, clothes, textures... Then I add in a background setting, a full prop, not a background. A city scene (Daz''s Walled City) At first, no problem at all and everything works smoothly. But then I revert back to before I put in teh city, try a couple other settings, but decide on using the city after all and reload it. That's when the problems begin and Poser Pro slows to a crawl. Just selecting a dial or trying to pull down a menu takes several minutes before responding. I've had this happen with some other props too. I even shut poser down all together and restarted it, but still the problem remains.
It's not like I'm running a slow computer. An athlon X2 6000 with 3 gig of ram.
Any one have any ideas?
Would this have anything to do with my crappy ATI X1300 video card? I hope so as I plan to get a new one at Christmas.
ockham posted Thu, 06 November 2008 at 3:44 PM
The same thing happened to me occasionally in P7.  I never figured it out; re-installed
a couple of times, and it stopped.
My python page
My ShareCG freebies
Willber posted Thu, 06 November 2008 at 5:32 PM
Does this still happen if you reboot the computer? Sometimes a reload of Poser is not enough....a complete shutdown is necessary.
That's all I can think of.
redtiger7 posted Thu, 06 November 2008 at 5:59 PM
Quote - Does this still happen if you reboot the computer? Sometimes a reload of Poser is not enough....a complete shutdown is necessary.
That's a  bit disturbing. Restarting your computer before loading each prop...
Winterclaw posted Thu, 06 November 2008 at 5:59 PM
Yes it still happens if you reboot.
I need to reinstall a few times like ockham said, but I'm a little lazy and don't want to go through the hassle of reloading everything on to my PC.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
Willber posted Thu, 06 November 2008 at 7:26 PM
I'm using Poser Pro and have not had this sort of experience that wasn't resolved by restarting Poser or Windoz....
What happens if you load a previous project after a clean start of the computer and Poser....same problem?
imagination304 posted Thu, 06 November 2008 at 7:48 PM
How about logout completely and login again?
cspear posted Fri, 07 November 2008 at 10:07 AM
If I get this I save what I'm doing and restart the pooter. That usually sorts it out.
PoserPro 11 - Units: Metres
Adobe CC 2017
icprncss2 posted Fri, 07 November 2008 at 10:37 AM
How many levels of undo do you have it set for and how often do you clear the undo cache?  Once you do a save on a scene, go into the prefs and clear the undo cache.  Sometimes P7 and Pro get bogged down when the undo cache gets too big.
Winterclaw posted Fri, 07 November 2008 at 1:28 PM
What's the max number of undos you can have without poser getting bogged down?
WARK!
cspear posted Sat, 15 November 2008 at 10:59 AM
If you're running Vista, here's a possible cause for P7 / PPro to act really slowly:
check what your default printer is set as. If it's a networked printer or a USB printer, it seems that some, but not all applications take their time polling the system to find that printer. Poser is one that does.
I found a simple fix: I set my default printer to the Adobe PDF writer ( not a real printer). I guess any PDF writer or a similar, software 'printer' would do.
Try it... it might work for you too.
Adobe CC 2017
Winterclaw posted Sat, 15 November 2008 at 1:59 PM
I have a network printer, but I have the MS XPS document writer as the default.
WARK!
