Subject: render figures with out background
bigdave1960 opened this issue on Nov 07, 2008 · 10 posts
bigdave1960 posted Fri, 07 November 2008 at 5:21 PM
is it possible to render a figure in poser with out any back ground so that a background could be added later in photoshop with out needing to "cut it out"?
BAR-CODE posted Fri, 07 November 2008 at 5:24 PM
yup render and save as a PNG ...
Chris
IF YOU WANT TO CONTACT BAR-CODE SENT A  PM to 26FAHRENHEIT  "same person"
Chris
My Free Stuff
bigdave1960 posted Fri, 07 November 2008 at 5:43 PM
Thank you most helpful and cheers for such aquick response
BAR-CODE posted Fri, 07 November 2008 at 5:46 PM
YW ... but remember only the plain background color will be transp ..
If you render a Tree orso in the back that still will be in the image...
Chris
Chris
My Free Stuff
bigdave1960 posted Fri, 07 November 2008 at 5:51 PM
yep thats ok my main problem is that ive had trouble with renders not finishing the image (but progress bar finishing and no error messages ) which seems to happen when i use a photo as a background so I thought i could drop the back ground photo in later in photoshop (might save some render time dont know
IsaoShi posted Fri, 07 November 2008 at 5:53 PM
... making sure, of course, that you have nothing in the scene background that will render, such as a skydome or backdrop. The Poser 'Background' itself does not render.
If you want to render ground shadows but not the ground itself, then go into the Material Room, select the GROUND prop, and tick "Shadow catch only".
If you get some fine or transparent edge details, especially hair, showing up grey against your background, then change the render settings to render against a black background, and that should improve it.
Happy rendering, BigDave!
(edit) x-post, sorry!
"If I were a shadow, I know I wouldn't like to be half of what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki Murakami)
bigdave1960 posted Fri, 07 November 2008 at 5:58 PM
cheers for that info
Daidalos posted Sat, 08 November 2008 at 6:19 AM
Isaoshi thanks for that little tutorial. :lol: I didn't know you could do that with the ground, saves me time adding it later on.
"The Blood is the life!"
Acadia posted Sat, 08 November 2008 at 8:09 AM
I also recommend that you change your render settings  to "Render over black background."  This will prevent you from having an ugly 1 pixel grey border around your image. There will still be a 1 pixel black border, but that looks more like a shadow than a border, and is much nicer.
However, when you are wanting to render something like a bride in a white dress, I suggest rendering over a white background so that the pixelation will blend in.
Paul Francis posted Sun, 09 November 2008 at 6:00 AM
I do it all the time, and can confirm that it works, and works well.  It's particularly effective if you put something (smoke, rain, light beams etc) in front of the figure as well as behind it, and between figures if you've got more than one.  I used the technique here:
http://www.renderosity.com/mod/gallery/index.php?image_id=1739943
My self-build system - Vista 64 on a Kingston 240GB SSD, Asus P5Q Pro MB, Quad 6600 CPU, 8 Gb Geil Black Dragon Ram, CoolerMaster HAF932 full tower chassis, EVGA Geforce GTX 750Ti Superclocked 2 Gb, Coolermaster V8 CPU aircooler, Enermax 600W Modular PSU, 240Gb SSD, 2Tb HDD storage, 28" LCD monitor, and more red LEDs than a grown man really needs.....I built it in 2008 and can't afford a new one, yet.....!
My Software - Poser Pro 2012, Photoshop, Bryce 6 and Borderlands......"Catch a  r--i---d-----e-----!"
