artposer opened this issue on Nov 10, 2008 · 6 posts
artposer posted Mon, 10 November 2008 at 4:01 PM
Is there anyway to change James as your default character when you first open Poser I know you can in Daz is this acheivable in Poser Pro or Poser 7. Does anyone use James? LOL
Winterclaw posted Mon, 10 November 2008 at 4:09 PM
Yes there is. I can't remember exactly what it is off the top of my head, but after some fighting with poser, I've managed to have no default figure.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
markschum posted Mon, 10 November 2008 at 4:10 PM
Sure , start poser and set up the scene the way you want it , then in preferences change use factory settings to user settings (not sure of exact wording) , then exit poser.
It should now start up with your settings.
artposer posted Mon, 10 November 2008 at 4:25 PM
Thank you
markschum posted Mon, 10 November 2008 at 4:36 PM
its in the manual , which is in pdf form in the poser program folder.
artposer posted Mon, 10 November 2008 at 4:44 PM
FYI That worked thank you........Set up your scene go to general preferences and under the document tab select Launch to preferred state. Then select the Set preferred state button restart and you are good to go.......
