doneydonydone opened this issue on Nov 13, 2008 · 13 posts
doneydonydone posted Thu, 13 November 2008 at 6:05 AM
HEY GUYS
IVE BEEN ASKIN IN A FEW OTHER FORUMS WITH NO LUCK SO I THOUGHT ID ASK THE PRO'S HEHE
DOES ANYONE KNOW THE FILTER OR PLUG IN THAT WOULD CREATE THIS EFFECT
ITS ON A TEE SHIRT OF MINE AND WOULD LOVE TO CREATE SOMETHIN SIMILAR FOR MY NEW UNI PROJECT
http://www.facebook.com/photo.php?p...28&id=586906304
THANKS IN ADVANCE
ejn posted Thu, 13 November 2008 at 6:37 AM
Couldnt get to see the photo as I am not a membe of fcebook.
You maybe could copy it and show it in the thread
doneydonydone posted Thu, 13 November 2008 at 7:00 AM
cheers ;o)
white-rose posted Thu, 13 November 2008 at 7:17 AM
I'm not sure but I think it looks like one from Penta called Jeans.
http://www.photoshop-filters.com/html/penta.htm
hope this helps
doneydonydone posted Thu, 13 November 2008 at 7:55 AM
that filter only adds a texture over the image
i want the filter that modifies the picture to make the light areas of my photgraph to be fat lines, the medium areas to be thin lines and the dark areas to be left out -- like the face in my pic
;0)
prixat posted Thu, 13 November 2008 at 2:04 PM
First change your image to greyscale, then the bitmap option becomes available.
Then change to bitmap and you will get this dialog.
change the method to halftone... and OK
regards
prixat
prixat posted Thu, 13 November 2008 at 2:07 PM
You will have to experiment with the frequency and angle but the shape has to be set to line.
regards
prixat
prixat posted Thu, 13 November 2008 at 2:11 PM
regards
prixat
bobbystahr posted Thu, 13 November 2008 at 3:23 PM
Here's a couple of things you might look into:
http://verlagmartinkoch.at/software/halftonepatterns/index.html
http://www.mways.co.uk/prog/plugin.php
Once
in a while I look around,
I see
a sound
and
try to write it down
Sometimes
they come out very soft
Tinkling light sound
The Sun comes up again
bobbystahr posted Thu, 13 November 2008 at 3:35 PM
Good tute prixat...never knew that...certainly a lot simpler than I thought...thanks.. ...
Once
I see
a sound
and
Sometimes
Mikewave posted Thu, 13 November 2008 at 7:53 PM
I concur; prixat for president!
Thelby posted Sat, 15 November 2008 at 7:23 AM
Yes, very much Thanks to Prixat and to Bobby for the links!!!
I would rather
be Politically Incorrect,
Then have Politically
Correct-Incorrectness!!!
Quest posted Sun, 16 November 2008 at 10:36 PM
Attached Link: http://www.panopticum.com/products_ps.shtml
Can also be done using Panopticum Engraver and some postwork.
