squirrel2005 opened this issue on Nov 14, 2008 · 4 posts
squirrel2005 posted Fri, 14 November 2008 at 6:10 AM
Hello!
I really hope you can help me out now... I have try this for such a loooong time.. and can't ascertain of it..
Every time I do import background in to my poser.... and render with it, it don't show up at the finished pose render...( use 7)
How come? how do I do it?
best regards Kim
People have the right to
be stupid. Some people abuse that privilege.
Kim Ch
hborre posted Fri, 14 November 2008 at 6:16 AM
Go to your render settings and on the right make sure that the pull down menu under 'render with' is set to background.
Tashar59 posted Fri, 14 November 2008 at 6:56 AM
The better way is to add the one-sided sqare in your props/ primitives. Then go to material room and add the image like a texture to the square. Make sure you turn the specular color to black or turn the value to 0.
Now the one thing you need to make sure of is the size of the square to fit the background image. If the background image is 600 X 800,.
Scale the square to xScale 600% X yScale 800%
Easy once you do it a couple of times. Then if the square is to small for your scene, use the main scale to fit. Remember to move the sqare back far enough to not collect any shadows and uncheck Cast shadows in the property tab. If you have any lights pointing from the back.
Sounds like a lot when I type this out but it will take you far less time to do it than my typing. LOL.
squirrel2005 posted Fri, 14 November 2008 at 10:40 AM
AW! Thanks to both of you!
I will give it a tray and come back if I still have some trouble...
It was very kind to help me out so fast :)
Kim Ch
