goofygrape opened this issue on Nov 29, 2008 · 10 posts
goofygrape posted Sat, 29 November 2008 at 1:18 AM
In my copy of CS2 ,only a hand full of preset filters show up?
PE7+ all ok.,CS2 add on ones work and show;clouds and render clouds different grey- ed out?
Any idea?
thanks
goofygrape
spedler posted Sat, 29 November 2008 at 9:52 AM
What's the image type? (menu Image->Mode)? Not all filters work in all modes. For example, in Lab Color, Clouds works but Difference Clouds doesn't.
Steve
goofygrape posted Sat, 29 November 2008 at 2:35 PM
Spedler:
Ok what I did was a new file and then a gradient ,went to render for clouds,no cloud option.
the idea was to make lighting,after some other things.I do not know about the image mode thing?
thanks
the grape
dreamer101 posted Sat, 29 November 2008 at 5:39 PM
When you go to File > New look at the Color Mode before you click OK. If file is already open go the Image > Mode. If it says Lab Color change it to RGB.
goofygrape posted Sun, 30 November 2008 at 1:54 AM
Dreamer101;
I checked and color is RGB.
when you start a new image and fill it you only have lens(flare,fibers)I am getting very good at making wood.no clouds tho.
thanks
the grape
spedler posted Sun, 30 November 2008 at 5:57 AM
Okay, when you create that new image, and the Color Mode says RGB, next to it there's another drop-down which can either say 8-bit or 16-bit. I think yours probably says 16-bit; the clouds filters won't work in that mode. If that's the case, change it to 8-bit and all will be well.
Steve
dreamer101 posted Sun, 30 November 2008 at 10:36 AM
Oh you are so right Steve! I never even thought of that. My hat's off to you. I shouldn't have jumped in so quickly with only half the answer.
spedler posted Sun, 30 November 2008 at 3:20 PM
Have to admit I didn't think of it at first, I thought the OP was probably using Lab Color.
Steve
goofygrape posted Sun, 30 November 2008 at 8:47 PM
thanks
and yes it is 16 bit going to change it now
bigjohn
retrocity posted Mon, 01 December 2008 at 10:25 PM
rats!!!
late again with offering an answer!
but the one thing i love about this forum is everybody is helpful.
thanks steve and dreamer!
scott
