Forum: Vue
Subject: VUE 6 espirit extras cd load problem
brewgirlca opened this issue on Nov 30, 2008 · 2 posts
brewgirlca posted Sun, 30 November 2008 at 9:42 PM
I cannot get VUE 6 espirit to recognize files from extras cd
I transfered all the files from the downloaded extras cd to c:documents/e-on software/vue 6 espirit/objects/ and /scenes
When I go to VUE load objects Architecture I just get Elements, House and Cottage, Large building and Monuments and just the historical fields except for sci-fi in Large. I am missing fantasy and sci-fi in all the rest. And I am missing bridges, lighthouse and mansions folders altogether. These files are present in My VUE folder on my c-drive but VUE cannot seem them.
Also I have no procedural terrains except the one that came with VUE. I downloaded them from the extras CD put them into the correct scenes folder but VUE does not recognize they are there.
When I use the browse button in the objects menu it will not let me select a folder only a file and if I select a file the description comes up but no picture in preview button. When I click on the file it says unable to read file xxxx.vobj
When I use the new collections button and click on a folder it comes back and says empty collection even if I am as far down in the root directory as possible ie arche/bridges/fantasy. But the files are there in:
directory path c:documents/e-on software/vue 6 espirit/objects/ bridges/fantasy
There is no jpgs associated with these vobj files…. Shouldn’t there be?
SAMS3D posted Mon, 01 December 2008 at 3:51 AM
You need to change your text color, I had to highlight it to read it.  When it shows it to you, isn't there an option for you to install the object?  You have to go to import first, then go to your files list if it is not in the pictures.
