ViperKilzz opened this issue on Dec 03, 2008 · 4 posts
ViperKilzz posted Wed, 03 December 2008 at 5:45 PM
Also, can someone direct me to a tutorial on using BUMP. I have rendered a couple of dresses and the render looks "flat" I'd like to add "bumpiness" for a more realistic look on fabric.
I am using P5
R I P MJ. He's must have needed an Angel escort in
Farrah
Please spay and neuter your pets. Strongly consider shelter
adoption before spending $500 to $1000. If you MUST part with that
kind of money for a pet, go to your local shelter, donate the money
to them and pickup a highly adoptable pet. The shelters could sure
use the donation.
markschum posted Wed, 03 December 2008 at 6:02 PM
If you mean dots along the edges that may require antialiasing.
Plutom posted Thu, 04 December 2008 at 9:29 AM
Plutom posted Thu, 04 December 2008 at 9:39 AM
There are other ways of making a bump: for example instead of connecting your image node to the bump channel like above, you can use a 3D node (there are 10 of those puppies with subnodes under each, just click on the bump channe little male plug and pass your cursor over the node that appears, more nodes open up including the 3D one, pass the cursor over that one and you get the 10 puppies, pass the cursor over one of them and select a node that looks interesting, click on it. Jan
