gaoray opened this issue on Dec 05, 2008 · 8 posts
gaoray posted Fri, 05 December 2008 at 1:25 PM
THANKS!
Model: V4 Honyu's Corset2 Stocking.
nickedshield posted Fri, 05 December 2008 at 2:20 PM
I haven't used V4 as much as I should so this may not help: After conforming the stockings, have you applied a magnet pose to it? That is one of V4's features. If memory serves, the magnets should be in the Pose library. If that is a single figure in the scene, use the first pose.
markschum posted Fri, 05 December 2008 at 2:28 PM
You can select the calf and turn off visibility. The stocking will still be there but you wont see the poke-through of the leg. You can only do that with bodyparts that are completely covered by clothing.
Winterclaw posted Fri, 05 December 2008 at 3:02 PM
Try seeing if there are any morphs you can use to fix the problem. Depending on the maker, they'll either be in the body group or in the individual area. A little tweaking can go a long way. Some merchants also put in morphs to fix things like bending problems.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
gaoray posted Fri, 05 December 2008 at 3:48 PM
I didn't knownwhy..... althrough, thanks for anwser my question again....
Still wait for this problem....
markschum posted Fri, 05 December 2008 at 3:57 PM
Sorry , I thought it was opaque :( You should contact the vendor and see what he says about the product. I am assuming that it conformed properly ?
shuy posted Fri, 05 December 2008 at 4:08 PM
Clothes may but not must have all morphs - depends what vendor claimed.
Try WW to transfer morphs.
JoEtzold posted Sat, 06 December 2008 at 12:15 PM
I have that set too. That stockings match perfectly.
If the shown happens first make sure you used the magnetise pose for the stockings (from V4 pose library).
Sometimes it may be neccessary to delete the stocking and reload, conform and magnetise it again. Than all should be solved. You can do so while V4 is posed, no need going back to zero position.
I'm not sure but might remember that there was also such a notice in the accompanying readme.
Jo
