blaack-widow opened this issue on Dec 17, 2008 · 2 posts
blaack-widow posted Wed, 17 December 2008 at 6:47 PM
first off I should mention this problem exsists on more then just NaikaV4. this is a figure that can "seamlessly" allow ANY clothes to fit her. which they do, but with a lot of adjustments. so I am trying to add morphs to the short pants I have that dont quite fit. they get sucked into her butt! those magnets really work. problem I have is I use the morph tool on one area, get the dial and it works fine. now I insert another morph target, I make a change and it seems to work. but if you move the dial one of 3 things happens.
anyone seen this issue before?
on a side note I'm not slamming this product. it is the most incredible body I've seen yet. but if you add more then 3-4 pieces of clothing and apply the magnets poser will crash every time. further testing proved its memory and I have 4g and a very good video card. but forget any kind of animation as well.
hborre posted Wed, 17 December 2008 at 11:46 PM Online Now!
Are you sure the clothing is a prop? Usually prop clothing is dynamic clothing meant to be applied in the Cloth Room. The other type of clothing is conforming, meant to better fit the model in a static position.
