Forum: Carrara
Subject: A few questions about Car 7 pro
hentsteph opened this issue on Dec 19, 2008 · 7 posts
hentsteph posted Fri, 19 December 2008 at 8:56 AM
The paint feature looks very nice, can you import your own brushes?
And in UV editing mode is there a pelt option?
Thanks
Steph
Portfolio
ren_mem posted Fri, 19 December 2008 at 9:13 AM
The brushes are just images, so yes you can add your own. Not sure what you mean by pelt mode. It does basically work like a pelt uv editor rather than an automatic unwrapper or lscm editor. You can mark seams and pins and unwrap it. Don't know if that is specifically what you wanted answered or not.
No need to think outside the box....
    Just make it invisible.
Xerxes0002 posted Fri, 19 December 2008 at 11:06 AM
I believe the Beta is still good for a little more time too over in the daz forums
hentsteph posted Fri, 19 December 2008 at 11:08 AM
I think it does, kind of like Hexagone then?
I meant the pelt mapping in Max, you mark seams and go into the pelt tool in order to unwrap.
Thanks
Steph
Portfolio
hentsteph posted Fri, 19 December 2008 at 11:09 AM
Quote - I believe the Beta is still good for a little more time too over in the daz forums
I wanted to check it out with the Beta but it's expired.
Thanks
Steph
Portfolio
ren_mem posted Sat, 20 December 2008 at 12:05 AM
The beta has expired. The program has been released. I am sure there will be a demo. There is also a 30day guarantee. It does work similar to hex. You go into the modeling and choose the UV button. There you can make your seams and add pins to to unwrap it.
bwtr posted Sat, 20 December 2008 at 1:30 AM
http://www.daz3d.com/i/software/carrara?_m=d
If you go quietly through this there are, also there, movie tutes which explain much.
Some C7 movies --6?,--have been placed on You-tube as well
Brian
bwtr
