Subject: A UK 3-pin plug model Request!
stu1234 opened this issue on Dec 21, 2008 · 11 posts
stu1234 posted Sun, 21 December 2008 at 5:17 PM
Jezz can you guys help me out?, Im looking for a basic free uk plug model.
markschum posted Sun, 21 December 2008 at 6:18 PM
http://www.turbosquid.com/3d-models/3d-max-power-plug/377994
sorry not free and I could not find a matching outlet
jonnybode posted Mon, 22 December 2008 at 2:07 AM
Hi Stu1234!
Check out this thread:
(You may have to be a member first but thats free)
www.planit3d.com/source/viewtopic.php
Regards / Jonny
pakled posted Mon, 22 December 2008 at 6:08 AM
just the plug? or some cable? I'm trying to remember what they look like (I'm in the US). Aren't they 3 circular pins? Been a good 20 years since I graced your shores...;)
nruddock posted Mon, 22 December 2008 at 7:54 AM
Attached Link: http://en.wikipedia.org/wiki/BS_1363
> Quote - just the plug? or some cable? I'm trying to remember what they look like (I'm in the US). Aren't they 3 circular pins? Been a good 20 years since I graced your shores...;)
Plugs here haven't used round pins for a very long time, and while change over period was also quite long, they were pretty much out of use by the late 70s.
The only round pin plugs that show up only occasionally are the 2 pin "Europlugs" with imported items that were made for other European markets rather than for the UK.
Some old (unmodernised) houses may still have the odd round pin socket or two, but nobody but a fool would trust wiring that old (if they're still connected).
stu1234 posted Mon, 22 December 2008 at 8:26 AM
something like this, doesn't even need to be in high detail or anything. I thought it would be pure simple to find but nope lol
spedler posted Mon, 22 December 2008 at 11:30 AM
I did this some time ago in C4D - if you are okay with just the exported .obj file and textures (such as they are!) you're welcome to it. You'll have to texture the pins yourself though, I didn't bother as in the end I didn't need to see them in the render I did.
Steve
stu1234 posted Mon, 22 December 2008 at 11:49 AM
Quote - I did this some time ago in C4D - if you are okay with just the exported .obj file and textures (such as they are!) you're welcome to it. You'll have to texture the pins yourself though, I didn't bother as in the end I didn't need to see them in the render I did.
That looks awesome man, could you send me it some how do you need my email or something?
spedler posted Mon, 22 December 2008 at 12:10 PM
I'll upload it to freestuff here, might be a bit later because I'm going out shortly. There's already a hole for a cable, I'll see if I can model in some fixing screws and I'll also correct the rotation of the live/neutral pins.
Steve
stu1234 posted Mon, 22 December 2008 at 12:16 PM
Quote - I'll upload it to freestuff here, might be a bit later because I'm going out shortly. There's already a hole for a cable, I'll see if I can model in some fixing screws and I'll also correct the rotation of the live/neutral pins.
WOW man thanks! I really appreciate it
spedler posted Mon, 22 December 2008 at 5:45 PM
Okay, I've uploaded this to the freestuff area but it needs to be approved first. Bare-bones model with a white texture and a bump map to show the BS kitemark. You'll need to get it working in Poser - I haven't tried it there but it should work. Might need scaling, for example.
Steve
