Forum: Carrara
Subject: Vertex Cube Smoothing?
chuckerii opened this issue on Dec 21, 2008 · 5 posts
chuckerii posted Sun, 21 December 2008 at 9:38 PM
Trying to make friends with the vertex modeler after many years of spline modeling.  I'm a little confused by this one... I insert a 3d cube in the vertex modeler and applying smoothing to it.  Nothing happens.  the corners and edges remain sharp.  I compare this to Hexagon where if you smooth a cube, it rounds all the corners and edges.   Is it not possible to smooth a cube in Carrara's vertex modeler, or what am I missing?
Chuck
Miss Nancy posted Sun, 21 December 2008 at 11:12 PM
it smooths it , if ya subdivide and weld first.
JohnMalv posted Mon, 22 December 2008 at 12:05 AM
Quote - Trying to make friends with the vertex modeler after many years of spline modeling.  I'm a little confused by this one... I insert a 3d cube in the vertex modeler and applying smoothing to it.  Nothing happens.  the corners and edges remain sharp.  I compare this to Hexagon where if you smooth a cube, it rounds all the corners and edges.   Is it not possible to smooth a cube in Carrara's vertex modeler, or what am I missing?
Chuck
Hey Chuck -
Cubes are created with creased edges. Select the cube so all faces turn red, then select "smooth edges" from the model menu. Then it will behave like Hex. Creased edges are blue when unselected and yellow when selected. Smooth edges are gray when unselected and red when selected. It confused me at first too.
John
GKDantas posted Mon, 22 December 2008 at 5:49 AM
Yes John is right, theres to kind of smooth: for polys and for edges, so in some cases (almost all) you will need to smooth the edges too in the model menu. This option let you use creased edges in smoothed objects.
Follow me at euQfiz Digital
chuckerii posted Mon, 22 December 2008 at 8:43 AM
Quote - Hey Chuck -
John
Thanks so much John!  Very clear and easy explanation... I appreciate the help.
Chuck
