cg3dstudio opened this issue on Dec 26, 2008 ยท 4 posts
cg3dstudio posted Fri, 26 December 2008 at 8:38 AM
HI,
I HAVE A HUGE RUNTIME LIBRARY IN MY POSER 7... CAN I COPY THIS RUNTIME FOLDER FROM MY POSER 7 TO MY POSER PRO ??
THE POSER PRO WILL READ THE COPIED RUNTIME FOLDER ??
markschum posted Fri, 26 December 2008 at 8:53 AM
You should be able to add it as an external runtime to Pro.
If you want to make a copy of it , copy it to a temporary folder, the copy the Poser pro runtime to the same folder, allowing it to replace any duplicate files , then copy the new combined runtime back to poser pro. Do NOT simply copy the poser 7 runtime to Poserpro, that will break things .
hborre posted Fri, 26 December 2008 at 11:01 AM
You need to be aware that single huge runtimes will consideralbly slow down your app and system. Really explore the feasibility of smaller external runtimes and stripping them down to the bare essentials. There is no need to have everything installed if they are not going to be used immediately, and limit your content usage to immediate projects. That way you can create your renders, then delete or transfer to other media the content you do not need anymore.
Gareee posted Fri, 26 December 2008 at 11:29 AM
