Subject: Simulating Muliple Items in Cloth Room
ViperKilzz opened this issue on Dec 27, 2008 · 3 posts
ViperKilzz posted Sat, 27 December 2008 at 4:02 PM
Greetings to All,
 I am using P5 V3
I have a set of dynamic cloths. One is the robe which goes over an Underskirt.
The Robe: how do I set it to collide against the normal body parts that it should and then against the over skirt.  When setting the 'Collide against' I checked off all the normal parts {hip, abdomen, Chest, right and left buttock, right and left shins and thighs then I checked off the under skirt. However when trying to set the collisions for the under skirt I get a message that I cannot set this because it was  checked off in the simulation for the robe.
Then I need to know how to clothify multiple items so that everything simulates at the same time?
Many thanks in advance
Viper
R I P MJ. He's must have needed an Angel escort in Farrah
Please spay and neuter your pets. Strongly consider shelter adoption before spending $500 to $1000. If you MUST part with that kind of money for a pet, go to your local shelter, donate the money to them and pickup a highly adoptable pet. The shelters could sure use the donation.
shuy posted Sat, 27 December 2008 at 4:46 PM
I do not remember P5 - maybe there is no this option.
In P6 and P7 make 2 simulation:
  1. skirt collide against all necessery body parts.
    2 when sim_1 is calculated make sim_2 for robe checking body parts (you can not check hip and maybe buttocks) and checking skirt.
Ofc both simulations must have the same frames to move together.
If it does not work search special offer on contentparadise - you have 3 days to get P6 for 30$.
markschum posted Sat, 27 December 2008 at 4:47 PM
You can only run one simulation at a time , For layered clothing I run each layer seperately and dont collide with figure chest if its colliding with shirt .
