smalll opened this issue on Jan 02, 2009 · 7 posts
smalll posted Fri, 02 January 2009 at 6:05 PM
Hi.
I'm beginner of poser.
My English is poor, I'm sorry.
I want to make a model.
And I want to turn off 'Use inverse kinematics' in default figure.
(You know Figure > Use inverse kinematics > Leftleg, Rightleg. )
It is so troublesome work to me.
So I want to edit cr2 file.
But I don't know where do I should edit cr2 file.
Can you help me?
DarkEdge posted Fri, 02 January 2009 at 6:12 PM
You can turn off inverse kinematics by going to:
Figure/UseInverseKinematics...and deselect them, or go to:
Window/HierarchyEditor...and you can turn them on and off at the bottom of the flyout panel.
smalll posted Fri, 02 January 2009 at 6:27 PM
Thanks to DarkEdge.
But I want to make it default When I double click the figure in library.
Can you help me?
hborre posted Fri, 02 January 2009 at 6:47 PM
This text editor by Dimension3d may solve your problem. It has a simple interface to trace the hierarchy nightmare of CR2 files.
smalll posted Fri, 02 January 2009 at 6:56 PM
Hi
Nice to see you Mr. hborre.
Thank you.
DarkEdge posted Fri, 02 January 2009 at 8:03 PM
If you happen to be working one one figure for the next few weeks you can always just load that figure onto the stage, turn off the IK's then go to: Edit/GeneralPreferences/SetToPreferrredState/LaunchToPreferredState
Then Poser will open to that figure with IK's off.
smalll posted Fri, 02 January 2009 at 8:11 PM
Thanks to DarkEdge.
I'll try.
