yblade opened this issue on Jan 06, 2009 · 12 posts
yblade posted Tue, 06 January 2009 at 6:48 AM
Hi, all
Because in the UV View don't see the textures applicate on the shaders ?
Select the face and aplicate UV planar but the texture in UV View don't see.
In the carrara 6 the texture to see .
Help
Carrara 7
Thanks
GKDantas posted Tue, 06 January 2009 at 7:29 AM
If not using procedural you need to turn on the texture view like you do in the Assembler Room. Here its working fine.
Follow me at euQfiz Digital
yblade posted Tue, 06 January 2009 at 7:58 AM
you can explain better?
thanks
GKDantas posted Tue, 06 January 2009 at 12:57 PM
yblade posted Tue, 06 January 2009 at 2:36 PM
Bug ????
GKDantas posted Tue, 06 January 2009 at 2:41 PM
Not a bug... look that your texture will be showed inside the grid, that is the UV area, so you need to reduce your UVMap to fit inside the grid.
yblade posted Tue, 06 January 2009 at 2:59 PM
Reduce UV bat nothing.
ShawnDriscoll posted Tue, 06 January 2009 at 3:18 PM
Not all textures show up in the UV view. Bricks/tiles don't. But most Enchance:C textures do.
GKDantas posted Tue, 06 January 2009 at 3:20 PM
ShawnDriscoll posted Tue, 06 January 2009 at 3:24 PM
Sometimes you have to guess how big to make your UV's so that the shaders look good on your objects. Or re-scale your shaders to make them look good with your UV's.
yblade posted Wed, 07 January 2009 at 4:45 AM
In Blender (open source) is perfect texture UV
In Carrara 6.2 is perfect texture UV
In Carrara 7.0 not perfect.
No No good.
I repented of update
GKDantas posted Wed, 07 January 2009 at 8:30 AM
Sorry blade but here works very fine...you are doing something wrong but at same time we cant see what is, if you want you can send me a PM to send me the file so I can check what is wrong.
