homeriscool opened this issue on Jan 06, 2009 · 12 posts
homeriscool posted Tue, 06 January 2009 at 12:49 PM
hi everyone, i bought this set last night but i cannot get it to work in poser 7 at all :( has anyone had this running on poser 7? market.renderosity.com/mod/bcs/index.php
BAR-CODE posted Tue, 06 January 2009 at 12:54 PM
but its a bunch of Obj file so i think they are props or figures ...
what is there to get working about it. ?
Did you read the Read me ?
IF YOU WANT TO CONTACT BAR-CODE SENT A PM to 26FAHRENHEIT "same person"
Chris
homeriscool posted Tue, 06 January 2009 at 1:03 PM
it simply will not show up in my runtime. i extracted the files to efrontier/poser 7 etc.... it says poser 5 in the read me, but i assumed poser 5 and above.
BAR-CODE posted Tue, 06 January 2009 at 1:06 PM
efrontier/poser 7 ??
Did you update the service pack ?
Then you might want to see if its not SmithMicro / poser7 now....
Other then that im still not sure what the problem is ..
Do you unzip from desktop or from within poser ? the two ways of unzip directs the itmes to diffrent locations
Chris
homeriscool posted Tue, 06 January 2009 at 1:09 PM
ah,maybe that is the problem? i will update now, see if it works. i switched updates off ages ago and havnt really used it for ages.....
nickedshield posted Tue, 06 January 2009 at 1:22 PM
Have you tried extracting to a dummy folder aand checking the folder structure? Sometimes it doesn't start with runetime so when you extract straight into Poser you will have to look for it. As far as p5 vs p7, the materials may or may not work properly. The readme did show where the files were placed. As Bar-Code mentioned, check the readme then see if the files are where it said they should be.
ir posted Tue, 06 January 2009 at 1:23 PM
It shouldn't matter whether it's "E-Frontier" or "Smith Micro". If you're unzipping using Winzip or the like, you're pointing to the "Poser 7" folder, what's above it is irrelevant.
homeriscool posted Tue, 06 January 2009 at 1:25 PM
to be honest , i didnt really think that updating my software was an issue, but i have just done it anyway - although it is a good suggestion :) , i will try again, with the unzipping......
BAR-CODE posted Tue, 06 January 2009 at 1:28 PM
Quote - to be honest , i didnt really think that updating my software was an issue, but i have just done it anyway - although it is a good suggestion :) , i will try again, with the unzipping......
did i say it was ? i asked if you did ... not that you should or must do it...
But when you change the main folder and work from that a unzipped file to a other folder wont be showing up in your runtime..
But simply look at what your doing and check the paths should bring you to your itmes..
And then you can check the paths to were they should be in poser...
Chris
homeriscool posted Tue, 06 January 2009 at 1:37 PM
i have updated my software, and i extracted from within the poser 7 folder- not from desktop and hey presto it works!!! i dont know what the differnce is, im quite puzzled, but at least it wasnt a waste of my money. thanks everyone - much appreciated!
homeriscool posted Tue, 06 January 2009 at 1:39 PM
Quote - > Quote - to be honest , i didnt really think that updating my software was an issue, but i have just done it anyway - although it is a good suggestion :) , i will try again, with the unzipping......
But when you change the main folder and work from that a unzipped file to a other folder wont be showing up in your runtime..But simply look at what your doing and check the paths should bring you to your itmes..
Thanks for all your help , much appreciated. :)
BAR-CODE posted Tue, 06 January 2009 at 1:39 PM
the diffrence is ... that like i said they 2 ways of extracting the zip does not put them in the same place....
The what and how is in the manual...
YW
Chris
