brewgirlca opened this issue on Jan 09, 2009 · 9 posts
brewgirlca posted Fri, 09 January 2009 at 10:06 AM
I want to set ambient occlusion to just be on skin surfaces of my figures.
So in the material room what "Poser Surfaces" do I hook up my Ambient Occlusion Node to? Are there any additional settings that need to be dialed in to make this work right?
I have tried hooking them to alternate specular and alternate diffuse and I just get pure white skin. And hooking to Ambient Color makes no difference from just leaving it at Depth Mapped shadows.
Also does ray tracing have to be turned on to make the Ambient Occlusion node work?
IsaoShi posted Fri, 09 January 2009 at 10:10 AM
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3099192
This thread by the master might be of interest...Also, in P7 and P Pro (not sure about P6) there is a Material Room Wacro button to add AO to a material.
And yes, AO requires Raytracing.
what I should be."
Murakami)
IsaoShi posted Fri, 09 January 2009 at 10:24 AM
Oops, I noticed in bb's thread that he says not to use the Wacro button, 'cos it connects the AO to the wrong place.
what I should be."
Murakami)
brewgirlca posted Fri, 09 January 2009 at 11:27 AM
Thanks IsaoShi. I read Bagginsbills instructions and will give it a whorl. If it is by BB I am sure it will work with a bit of fiddling!
IsaoShi posted Fri, 09 January 2009 at 11:35 AM
Is a whorl something between a whore and a whirl? Whatever, it sounds like fun for a bad girl.
xx
Izi
what I should be."
Murakami)
hborre posted Fri, 09 January 2009 at 12:50 PM
The hook-up is to Diffuse_value and Highlight_value, if I remember correctly. Not at my home computer, so I can't verify the settings. The default value for AO is 3 but that can be taken up to 7.
bagginsbill posted Fri, 09 January 2009 at 2:17 PM
Not Highlight_Value (or Specular_Value) - read my tutorial. I demonstrated, using a ball in a cup, why it is totally wrong to put AO on specular effects.
Only Diffuse_Value.
hborre posted Fri, 09 January 2009 at 2:47 PM
Thanks for the correction, BB.
brewgirlca posted Fri, 09 January 2009 at 3:26 PM
Thanks everyone. I used Baginsbills tutorial and it works just great!
