Forum: Vue
Subject: Vue and Poser Victoria 4
ARCHITECT opened this issue on Jan 10, 2009 ยท 3 posts
ARCHITECT posted Sat, 10 January 2009 at 3:44 AM
I have some problems when I try to import a Vicky 4 into my Vue 6 - all the poses are gone and V4 is "zero-posed". Is this a bug? There's no problem when I use a Vicky 3... This only happens to V4.
What can I do to import my scene into Vue without exporting it as a obj-file from within poser 7?
melikia posted Sat, 10 January 2009 at 3:49 AM
In poser... Turn off "Use External Binary Morphs" under your options/settings.
anything you created using V4 prior to this will not load correctly, but after applying this setting, everything should be fine =D
Rarer than a hairy egg and madder than a box of frogs....
< o > < o >    You've been VUED!    < o > < o >
         O                                                    O
thefixer posted Sat, 10 January 2009 at 3:56 AM
Also if you've used dynamic cloth, you need to bring her in at the final frame of the series.
E.g. If you used dynamic cloth up to frame 30, bring her into Vue at frame 30 or 29, I always use 29!
Injustice will be avenged.
Cofiwch Dryweryn.
