Nyghtfall opened this issue on Jan 20, 2009 · 5 posts
Nyghtfall posted Tue, 20 January 2009 at 1:45 AM
Does Poser 7 have a system for allowing only realistic joint positioning for figures, similar to DAZ?
svdl posted Tue, 20 January 2009 at 2:52 AM
THere's a "Use limits" option, which prevents joints from bending too far.
Nyghtfall posted Tue, 20 January 2009 at 9:08 AM
Good deal. Thanks.
Fazzel posted Tue, 20 January 2009 at 10:00 AM
I'd go with Poser Pro or Poser Pro Base if I were you. Only costs a little bit more
and you get more features. If you already have Poser 6, Poser Pro Base is $149.
While Poser 7 is $129. So for $20 more you get a 64 bit render engine, network
rendering, animation layers, gamma correction and everything in Poser 7.
PP is sort of Poser 7.5.
Nyghtfall posted Tue, 20 January 2009 at 12:55 PM
Quote - I'd go with Poser Pro or Poser Pro Base if I were you.
Thanks for the tip. I'll look into that.
Quote - If you already have Poser 6, Poser Pro Base is $149.
I currently don't have any version of Poser. I've just been noodling around with DAZ, off and on, for the last three years.
