kedo1981 opened this issue on Jan 25, 2009 · 5 posts
kedo1981 posted Sun, 25 January 2009 at 7:49 AM
Reflections on being slow
I know I should have thought of this a long time ago (been using since ver.3) so please don’t make fun of me.
My animations in carrara 6 mostly involve showing some kind of process using my companies CAD models.
I usually set the BACKDROP to cromakey green to later comp in After Effects or Vegas.
I was never much satisfied with the way the reflections turn out.
Most of the models I work on are of machined metal components.
Just last week I realized I could have a reflection map in the BACKGROUND channel and still use the green screen in the BACKDROP, thus getting the nice metal reflections and still render out to a good key.
DUUUUUUUU
Patrick_210 posted Sun, 25 January 2009 at 8:22 AM
You could also use an HDRI to further enhance the effect.
GKDantas posted Sun, 25 January 2009 at 8:36 AM
And you can use alpha channel for better composite in After Effects, so you dont need a green backdrop.
Follow me at euQfiz Digital
sfdex posted Sun, 25 January 2009 at 1:18 PM
The problem with Carrara's alpha channel in render is that it doesn't handle blurs well, so if you're rendering with motion blur, you're better off using a chroma-key green background and doing the composite with Keylight in AfterEffects. Keylight handles blurs and semi-transparent areas really well, in my experience.
- Dex
GKDantas posted Sun, 25 January 2009 at 2:07 PM
I see, never did something with motion blur... by the way can you show your work with Carrara?
