freefall565 opened this issue on Jan 31, 2009 · 7 posts
freefall565 posted Sat, 31 January 2009 at 11:06 PM
I'm trying to convert and obj. file to a poser character, which I have successfuly done. However when I go to pose her I get breaks and don't know how to fix them. Can someone please help?
Winterclaw posted Sat, 31 January 2009 at 11:30 PM
Is inverse knetics turned off?
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
freefall565 posted Sat, 31 January 2009 at 11:51 PM
geep posted Sun, 01 February 2009 at 3:47 AM
Turn ON "Bend Body Parts"
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
freefall565 posted Sun, 01 February 2009 at 7:21 AM
unfortunately it was already on, not sure what to do
geep posted Sun, 01 February 2009 at 8:25 AM
There are 2 places where "Bend" must be ON, i.e., checked.
= AND=
If both of these are ON (checked) and you still have the problem, then the joint between the body parts has not been properly "welded."
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
lesbentley posted Sun, 01 February 2009 at 4:42 PM
Check the weld statements in the 'figure' section of the cr2. Below is a snippet from the welds in the P4 Nude Woman to show what welds should look like. after the welds is a line "allowsBending" this should have a value of one. Also each individual actor needs to contain the line "bend 1", except the eyes, which should usually be set to "bend 0".
weld lThigh:1
hip:1
weld lShin:1
lThigh:1
weld lFoot:1
lShin:1
weld lToe:1
lFoot:1
allowsBending 1
