richardson opened this issue on Feb 01, 2009 · 13 posts
richardson posted Sun, 01 February 2009 at 5:25 PM
I have an INJ/REM file made now of an old V3 fbm (Geometry export) modeled in ZBrush. I never posted it due to too many quirks,, some have been solved. Some not.
I used to hack (point) a cr2 to my obj and just mess with it but this time I used a py script by svdl to produce an INJ/REM. This works flawlessly. The eyes, I find need an offset on X 0.103 (Right), X-0.103(left). This in turn requires a correction in "side to side" of -5.0 and 5 (left) respectfully..
This gets them on their centers and do not "open" at the lacrimals anymore. Should I hack the INJ file to do this or, do another technique with the cr2? Then,,, a new INJ file..?
richardson posted Sun, 01 February 2009 at 5:30 PM
SSAfam1 posted Sun, 01 February 2009 at 5:52 PM
richardson posted Sun, 01 February 2009 at 5:58 PM
It was aaa3d but, I see he has removed to skin pack. I see these irises everywhere. Sure it was taken from a photographic pay source...
SSAfam1 posted Sun, 01 February 2009 at 6:08 PM
Quote - It was aaa3d but, I see he has removed to skin pack. I see these irises everywhere. Sure it was taken from a photographic pay source...
Thank you.
They are very nice. I would've liked to purchase them.
lesbentley posted Mon, 02 February 2009 at 4:00 AM
I'm at colledge at the moment, so can't go into detail, as I'm suposet to be doing other stuff. What figure is this for, or more importantly is it a figure that uses the DAZ PBMCC_## morph channels?
I'll try to get back to you this evening. In the meantime you might like to take a look at my thread "A Compendium of PZ2 Techniques" the third postt on page three "The Monster Eyes Problem (part 1).".
santicor posted Mon, 02 February 2009 at 6:13 AM
i tried making an injection morph which not only added a "MyFigure" dial to the head, but also a "MyFigure" dial to the lefteye and righteye body parts in their correct position.
It worked OK but the eyes don't move around so accurately now when I make her look around .....this prob is discussed in the thread that Les referenced. I am anxious to keep learning aout this problem its a big problem for me right now. Thanks for asking this question.
______________________
"When you have to shoot ...
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
http://www.renderosity.com/homepage.php?page=3&userid=580115
santicor posted Mon, 02 February 2009 at 6:21 AM
pretty awesome skin shader in those images, BTW .....
did that skin package include the bump/displacement node settings and maps?
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
bagginsbill posted Mon, 02 February 2009 at 6:37 AM
Quote - pretty awesome skin shader in those images, BTW .....
Don't tell richardson, that. He'll become insufferably proud of himself. :kidding: ;-)
Those are not shaders. Those are not even renders. That is the straight preview out of Poser.
santicor posted Mon, 02 February 2009 at 8:03 AM
Well then I guess it's a pretty awesome texture map when viewed on high resolution preview ;-)
BB, I am wating for your math sollution to skin wrinkles and pores. Thanks.
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
richardson posted Mon, 02 February 2009 at 10:06 AM
This is a V3 morph. Page 3 looks promising on that link. I'll try it tonight. This , I hope "sticks" with the figure.. I've had a lot of trouble. Oddly,, Setting the eyes inboard, finds their rotation centers on V3..;/ this drove me maddd a few years ago. Rotating past 35 degrees shows how off far off they really were. V4 solved this. Close anyway.
;).. V4 has better preview still! She's 3x 4096 tall.
lesbentley posted Mon, 02 February 2009 at 4:04 PM
I'm not sure that I can add much to the information in the link from my last post. Give it a try and if you have any problems, or if there is something that you don't understand report back here and I will try to help. Here is an example of a pose file to slave the translations of the eyes to a morph in the head named "HeadMorph". The values in the 'deltaAddDelta' lines are the values read from the translate dials after the eyes have been translated to fit the morphed eye sockets.
//EyeSlaveExample.pz2
version
number 3
actor rightEye
channels
translateX xtran
valueOpDeltaAdd
Figure
head
HeadMorph
deltaAddDelta -0.002005
translateY ytran
valueOpDeltaAdd
Figure
head
HeadMorph
deltaAddDelta -0.0002
translateZ ztran
valueOpDeltaAdd
Figure
head
HeadMorph
deltaAddDelta 0.004
actor leftEye
channels
translateX xtran
valueOpDeltaAdd
Figure
head
HeadMorph
deltaAddDelta 0.002005
translateY ytran
valueOpDeltaAdd
Figure
head
HeadMorph
translateZ ztran
valueOpDeltaAdd
Figure
head
HeadMorph
deltaAddDelta 0.004
I don't have V3 installed at the moment, but you seem to sugest that the default 'origin' (centre of rotation) for her eyes are not in the optimal location, this does not really surprise me. You can change the location of the 'origin' via a pose file. Below is an example of a file to change the origins, endPoints, and orientation. { //JessiEyeOrigin.pz2 //A file to change the eye origins. version { number 3 } actor rightEye { channels {
endPoint -0.014 0.655 0.049
origin -0.0110957 0.653383 0.0280001
orientation 0 -8.6 0
actor leftEye
channels
endPoint 0.014 0.655 0.049
origin 0.0110957 0.653383 0.0280001
orientation 0 8.6 0
Of course you don't need to use three separate pose files, one to load the morph deltas, one to slave the translations, and one to adjust the origins. These three functions can all be integrated into one one pz2.
P.S. In this example the eye actors are named "rightEye" and "leftEye", and this is the common naming convention for eyes, but V4 uses the names "lEye" and "rEye". So those following these examples for V4 for will need to edit the eye names appropriately.
richardson posted Mon, 02 February 2009 at 5:36 PM
Thankyou Les..
We're working late so I'll have to do this later. I'm following so far.
