Forum: Poser Technical
Subject: Un Doing a parent command
westcat opened this issue on Feb 04, 2009 · 5 posts
westcat posted Wed, 04 February 2009 at 4:48 AM
I have two figures in a scene that are parented to one another.  Where in Poser is a command that will undo a parent?
PhilC posted Wed, 04 February 2009 at 4:53 AM
Figure > Set figure parent > (select) UNIVERSE
Hope that helps.
westcat posted Wed, 04 February 2009 at 5:18 AM
yes thanks
ratscloset posted Thu, 12 February 2009 at 4:14 PM
Just adding...If you Parented a Hand or another part in the IK Chain you will need to Parent it back to the chain Part or you will mess up the IK.. (I have seen people do this)
ratscloset
aka John
lesbentley posted Fri, 13 February 2009 at 12:04 PM
I don't know about P7, but for me in P4 through P6 "Figure > Set figure parent > (select) UNIVERSE" does not work! Neither can I set the parent to UNIVERSE in the Hierarchy Editor.
The only way that works for me is to select the Body of the child figure, then from to Object menu > Change Parent, and set the parent to UNIVERSE there.
