Subject: Slightly OT : For The Tech Heads - New PC System for Poser v7
mathman opened this issue on Feb 05, 2009 · 12 posts
mathman posted Thu, 05 February 2009 at 11:33 PM
Hi all,
I'm still shopping around for a new PC. I have seen the following specs advertised (quotes in Aussie $), and was wondering if I could get some feedback from the more technical among you - whether you think these would be suitable for Poser :
AMD AM2 Sempron LE-1250 ($ 340)  ... or
AMD AM2 x2 Dual Core 5200+ ($ 380)  ... or
AMD AM2 Athlon LE-1620 ($ 350)  ... or
AMD AM2 x2 Dual Core 5400+ ($ 390)  ... or
AMD AM2 x2 Dual Core 6000+ ($ 430)  ... or
AMD AM2 x4 Core Quad 9550+ ($ 500)
With ....
  1. “Genuine” AMD AM2 940 Pin Sempron, Athlon64 or AMD Athlon64 x2 Dual Core Processor
  2. “NEW” ASUS M2N68 AM2 Nvidia Chipset -Multi-Layers Socket AM2 940 Motherboard (AMD Approved Motherboard) “Genuine” AMD COOLING FAN & HEATSINK
  3. Latest AMD AM2 Technology & Re-Programmable Flash Plug & Play BIOS
  4. Genuine Super Fast Synchronous Pipeline Burst CACHE Built-In On CPU
  5. On Board Enhanced “Ultra DMA 133/100 (ATA100) Bus Master Ready” IDE Controller And Floppy Drive Port
  6. On Board 1xPCI-E Ports, 4 x Enhanced USB Ports, 1 x 16550 High Speed UART Serial Ports,1 x SPP/ECP/EPP Parallel Port
  7. “80GB” 7200rpm Ultra DMA 100 (ATA-100) Enhanced Cached IDE Dual Channel Hard Disk Drive
  8. “1GB” DDR2 (Double Data Ram) Memory- High Speed RAM With EPROM (AMD Approved)
  9. “512MB” ATI 3450 16x 3D PCI-E Video Display Card -512MB 128 Bit Blaze High Speed 2D/3D Video Card Support DirectX 9 with Full Screen MPEG/DVD Playback True Colour Graphic Accelerator Card
  10. Network Card (Integrated)
  11. ASUS “6 Channel” AC97 Digital Audio Stereo Plug & Play Sound Card(Integrated)
  12. Quality 2.0 Channel Multi-Media Powered Amplified Shielded Speakers
  13. TOP Quality “SHAW” 550Watt. Deluxe (AMD XP Support)ATX (Full Depth Size) Medium Tower Case
  14. “Genuine” Gigabyte PS2 Keyboard & PS2 Ergonomic Optical Mouse
  15. Full Set Of User Certificate, Disks, CDs, and Manuals. Software, And 24Hrs Plus Performance + Burn-In Test
  16. 60 Month Return To Base Labour(Hardware Diagnotics) Warranty, 12 Month Return To Base Parts(Hardware ONLY) Warranty*
What do you think ?
thanks,
Andrew
