bigbearaaa opened this issue on Feb 12, 2009 · 6 posts
bigbearaaa posted Thu, 12 February 2009 at 9:34 PM
I'm starting to get extremely frustrated with Carrara. How am I supposed to build a scene when Carrara keeps creating a new document every time I try to add a new element to the picture. I've played with the insert menu but inserting content objects doesn't seem to be an option.
I'd really like to do something simple to start with such as put the hot tub onto a terrain and build a landscape for it but Carrara doesn't act at all like ANY other of the programs that I have (they all let you work on a single document and don't open anything you don't ask for).
Even if you're working on an animation you want to build a single scene as a start point so this isn't something the program shouldn't do. It's already doing something it shouldn't do in opening new documents instead of adding elements to the current scene.
MarkBremmer posted Thu, 12 February 2009 at 9:59 PM
How are you adding elements to your scene? Please explain your steps a little more.
With a document open, you can just drag them from the browser into your scene in the Assembly Room.
If you're bringing in a 3D model from somewhere else, simply use the import function (File => Import) in the pull down menu.
Mark
GKDantas posted Fri, 13 February 2009 at 7:41 AM
I ask the same question...theres something wrong here. Try some of my siomple tutorials about working with content at CL:
http://carraralounge.com/index.php?topic=64.0
Follow me at euQfiz Digital
sparrownightmare posted Fri, 13 February 2009 at 4:51 PM
7 is really starting to bug me too. I never had these issues with 6. I can't change master shaders in shading domains or I get that cryptic and totally unuseful An error has occured....blah blah message.
GKDantas posted Fri, 13 February 2009 at 6:15 PM
Public Beta for Carrara 7.1 is out at Daz now:
http://forum.daz3d.com/viewtopic.php?t=106250
sparrownightmare posted Fri, 13 February 2009 at 9:20 PM
Eegads that was fast...
