Subject: Model rigging
fiction2002 opened this issue on Feb 17, 2009 · 6 posts
fiction2002 posted Tue, 17 February 2009 at 11:44 AM
I'm a 3D modeler, and I'd like to rig some of my models for Poser, so that I can put them on the marketplace, and maybe even a freebie here and there.
My problem is that after I get the bones set up in Poser and I bind them to the model, parts of the poly-mesh break up as I pose it.  The shoulder will tear right off the arm, and so on.  Some of this appears to be because of the grouping, which I can work on, but some just seems wrong.
If anyone has experience rigging models in Poser, could you give me some tips to fix this?
Thanks!
geep posted Tue, 17 February 2009 at 12:10 PM
[ X ] "Bend Body Parts"  <<< You prolly need to do this. 😄
It's on the main menu under "Display" >>> "Bend Body Parts"
There is, also, a [X] Bend for each Body Part in the "Properties" window under [X]  "Visible".
If these do not fix your problem, you may need  to "weld" the body parts.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
fiction2002 posted Tue, 17 February 2009 at 12:14 PM
Thanks for that!  It's already set, though.  Some of it clears up when I tweak the grouping, but not all of it.  For instance, I have an upper arm with the bone grouped perfectly to that upper arm geometry.  When I bend it, the mesh tears at the shoulder and underarm.
Any other ideas? :-)
fiction2002 posted Tue, 17 February 2009 at 12:55 PM
I did some digging around on the 'net, and found this:
http://my.smithmicro.com/tutorials/44.html
I think this will take care of it for me, and possibly help others.  If I still have problems, I'll post them here.
markschum posted Tue, 17 February 2009 at 1:22 PM
You have sets of inclusion and exclusion zones and the spherical falloffs for each joint.  There is a bend paparamter on the body part properties display.
TrekkieGrrrl posted Tue, 17 February 2009 at 4:12 PM
 The thing about the shoulder breaking off sounds like a missing WELD parameter to me. Poser needs all groups welded :)
