Forum: Community Center
Subject: Image size in forums
spedler opened this issue on Feb 18, 2009 · 6 posts
spedler posted Wed, 18 February 2009 at 9:00 AM
Okay, time to display some (more) ignorance. When I insert an image into a forum post I click the 'insert image' button in the editor, and enter a full URL to the image in the 'image info' tab. The image itself is held on my web host. All that works fine... except that the image appears full size in the post, which can throw the page formatting off.
Almost everyone else seems to have a smaller sized image in their posts, which when clicked shows the full size image. The URL for that link is a renderosity URL rather than an offsite one, and always looks something like "http://www.renderosity.com/mod/forumpro/media/folder_9/some_file.jpg". I want to use this same resized image arrangement. How is it done? I've searched on this site and can't find it anywhere. I'm clearly missing something obvious.
Help would be gratefully received.
Steve
tantarus posted Wed, 18 February 2009 at 9:04 AM
Attach a file :)
Click on Browse and load image from your HDD, no need for hosting it online :)
Tihomir
Open your mind and share the knowledge!
CaptainJack1 posted Wed, 18 February 2009 at 9:11 AM
If you know HTML, you can click the "Source" button in the upper left hand corner of the reply window. It shows you the HTML source of your message. You can insert the link manually using this format:
Where you specify the width and height you want it to display as. If you want them to be able to see the full size image, wrap a link anchor around the image tag.
spedler posted Wed, 18 February 2009 at 9:44 AM
> Quote - Attach a file :) > Click on Browse and load image from your HDD, no need for hosting it online :)
Aaargh! You mean that for years I've been unnecessarily uploading files to a web host and I didn't need to!  Now I feel a complete dunce :-)
Many thanks for pointing out what should have been obvious :biggrin:
Steve
spedler posted Wed, 18 February 2009 at 9:46 AM
Quote - If you know HTML, you can click the "Source" button in the upper left hand corner of the reply window. It shows you the HTML source of your message. You can insert the link manually using this format:
Yes, thanks - that's a useful technique if the image has to be inline, the attached file technique always seems to put the image right at the start of the post.
Steve
tantarus posted Wed, 18 February 2009 at 10:28 AM
Lolol, you have just overlooked the option :)
Tihomir
