decadence opened this issue on Feb 22, 2009 · 2 posts
decadence posted Sun, 22 February 2009 at 9:52 AM
Hi all I was hoping somebody might be able to help. I am creating an animation in Vueof two different M2 figures walking on their own seperate walk path. I created the walk path and animation in poser for each (seperate files). I can import each one into vue and they animate fine. But when I import one figure then add the second one into Vue only one poser figure animates (walks) , whichever is the last one I imported.
In another experiement I duplicated the same figure into the same scene (in Vue) and then both (same figures) walked together. I'm not sure why that works, but two different poser figures will not work together for some reason. The only things I can think of is that each have different keyframe rates/frames? Or the walk path is called the same thing in Poser for both figures and one overwrites the other when I import into Vue.
Any suggestions or ideas how I can fix this? Thanks in advance!!!!
decadence posted Mon, 23 February 2009 at 1:37 PM
Well I guess nobody has run into this issue before. I must be the first.....
After some tests here is what i have discovered although I don't have an answer.
I still can't seem to import two different animations from poser into Vue 6 and have them both animated in the same scene. I can create a single animation, import into Vue and then make multiply copies of that animation object while I'm in Vue.But I don't want multply copies of the same thing ...
I finally came up with a possible solution but for some reason I don't think its the right one although it worked for me. I created an animation in poser using two figures walking along two seperate walk paths. then I imported that whole scene with both poser figures into Vue and it seemed to work just fine. Actaully i had three separate figures in the animation. the third one was not walking. Again everything work fine.
What appears to happen when importing separate animations in Vue is the last animation will be animated in Vue but any prior animations loose their...animation. Strange. I'm sure there must be something I need to select or deselect or whatever to get all animations imported into Vue to work...who knows. If you know please let me know.
