artbyphil opened this issue on Mar 12, 2009 · 7 posts
artbyphil posted Thu, 12 March 2009 at 9:14 AM
I opened a new large empty scene, go to atmosphere choose a sky from the presets. In the preview it looks fine but when I render I just get a blue sky with no clouds showing. I’ve tried adjusting the settings but it doesn’t seem to do any thing.
If I use a realistic sky setting that seems to work.
Just wondered what I’m doing wrong
Cheers
MarkBremmer posted Thu, 12 March 2009 at 9:18 AM
I looks as if your camera is pointing straight up - can't really tell without seeing the Assembly Room.
Mark
artbyphil posted Thu, 12 March 2009 at 9:40 AM
artbyphil posted Thu, 12 March 2009 at 9:45 AM
MarkBremmer posted Thu, 12 March 2009 at 9:45 AM
Ok, I see what's going on. I looks like you've chosen the Large scene size. I missed your earlier comment about using Realistic Sky v.s. the"old" sky settings. The Realistic Sky respects the scene scale - the other Sky setting does not. So, your clouds are really, really low; the camera is above them. You an adjust the altitude
I haven't used the "old" sky settings for so long that I forgot about this little quirk.
artbyphil posted Thu, 12 March 2009 at 10:02 AM
ha! cheers I'll have a play with that.
Does using real skys add alot to render times? if not I suppose its better to use then anyway.
I've been a bryce user for years but this seems like it will be good (when i get the hang of it :)
MarkBremmer posted Thu, 12 March 2009 at 10:18 AM
I used Bryce for years myself but the render times made it impossible to use professionally. Carrara has a pretty solid environmental capability. Post back with questions. You willl have to bend the brain a little bit just because of a different way of doing things.
However, after spending a little time, I don't think you'll be looking back. :-)
