Forum: DAZ|Studio
Subject: Daz models into poser
thekingtut opened this issue on Mar 13, 2009 · 5 posts
thekingtut posted Fri, 13 March 2009 at 1:29 PM
I have D/S and Poser on my computer. What I want to know is how do you get V4.2, M4 and others into Poser. I want to see what I can do in Poser with them.
3DFineries posted Fri, 13 March 2009 at 1:55 PM
I'm pretty sure they have to be installed directly into your Poser runtime.
P.S. Edited to add.  You also have to install their morphs in the same folder.
Have a creative day!
My Lil' Store
RHaseltine posted Fri, 13 March 2009 at 3:25 PM
Which version of Poser? 7 can cope with M4 and V4 in an external folder, so you just need to tell it to use the Content folder or wherever you installed to as an external Runtime (keep double-clicking the up-a-level icon in the Library panel until you hit the top, with just Poser and Downloads listed if you haven't already added folders) then click the + button at the bottom of the panel and select the folder that holds the Runtime folder with M4/V4 in it. If you don't have SR3 for Poser 7 you will need to set the Search behaviour to shallow in Edit>General preferences. If you have Poser 6 or earlier then you do need to install M4 and V4 (and morph sets) to the Poser folder, unfortunately.
thekingtut posted Fri, 13 March 2009 at 7:45 PM
It's Poser 7. I'll try your method R Haseltine. I'll report back.
thekingtut posted Fri, 13 March 2009 at 8:47 PM
Worked. Thanks to the both of you.
