Subject: how can i get good wet looking hair?
homeriscool opened this issue on Mar 13, 2009 · 15 posts
homeriscool posted Fri, 13 March 2009 at 9:24 PM
hi everyone, i am just wanting to learn how i can do wet hair, or even buy wet long female hair. can anyone help? thanks in advance. ps i have looked in the market place.
Morkonan posted Fri, 13 March 2009 at 11:53 PM
Quote - hi everyone, i am just wanting to learn how i can do wet hair, or even buy wet long female hair. can anyone help? thanks in advance. ps i have looked in the market place.
There's a couple of "wet hairs" out there.  Not sure if the most popular one is here or at DAZ3D.com.  Try looking in both spots searching for "wet hair."  They're definitely out there, saw one last week (at DAZ I think) when I was looking through different hairs.
As far as doing it yourself, you could model some using a 3D modelling application.  Or, you could try taking some hair you already have and using magnets and/or the Morph Tool (Poser 7 and up) to flatten it out a bit.  Increase specularity for a good wet look and you might get by with it.
vholf posted Sat, 14 March 2009 at 1:53 AM
Here's the one I know.
www.daz3d.com/i/3d-models/-/wet-hair
ice-boy posted Sat, 14 March 2009 at 10:06 AM
this is the problem
every hair has hes own specular highlights.
when you are using modeled hair its made out of planet with a transparency map.
this is how a simple plane looks with specular
and it would look the same with a texture and transparency map.
this is of course not good. and its not realistic.
ice-boy posted Sat, 14 March 2009 at 10:14 AM
it would be nice if i i could in photoshop make a image and then tell poser that every white line should have a seperate specular.
ice-boy posted Sat, 14 March 2009 at 10:21 AM
this is how they should do modeled hair. more planetsthe better IMO
www.zbrushcentral.com/zbc/showthread.php
images edited by a mod for size
SSAfam1 posted Sat, 14 March 2009 at 10:58 AM
^I seriously love the clothes for those models.
JenX posted Sat, 14 March 2009 at 11:34 AM
Quote - it would be nice if i i could in photoshop make a image and then tell poser that every white line should have a seperate specular.
That's why you don't use straight white.  You use a gradient of different shades from black to white.  Making a 2-color specular map is pretty self-defeating.
I've actually found that you get better specularity on hair when you use a shader rather than an image map based specularity in the Alternate Specular node, using the Anisotropic node.  A MUST is that your hair has a GOOD Bump map attached so differentiating between strands of hair is visible.
Sitemail | Freestuff | Craftythings | Youtube|
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it into a fruit salad.
ice-boy posted Sat, 14 March 2009 at 11:53 AM
i understand nothing.nothing. what are you talking about.
cmcc posted Sat, 14 March 2009 at 6:57 PM
Attached Link: http://artcomp1.tripod.com
these r terriffic.
Computer Art by Charles McChesney
TrekkieGrrrl posted Sat, 14 March 2009 at 7:12 PM
Quote - > Quote - it would be nice if i i could in photoshop make a image and then tell poser that every white line should have a seperate specular.
The key thing is to plug the Transparency map into the specular, too. That way you will have specular only on the stands and not the whole plane.
I fail to see how the Zbrush hair differs much from how most Poser hair is modeled btw. Take a look at Neftis' hair. It has at least as many individual planes as the one in your examples.
And anyway, a hair with a zillion planes and a crappy mapping can look much worse than a hair with two planes and a GOOD mapping. Look at Kozaburo's hair for an example of the latter.
ice-boy posted Sun, 15 March 2009 at 4:56 AM
it doesnt matter if you plus the transpareny map in spcular . it doesnt matter if you have a specular map. teh characteristic of hairs specular is different.
FrankT posted Sun, 15 March 2009 at 2:30 PM
In theory, you'd use an anisotropic specular highlight on the hair - works ok in Vue but I don't know how accurate the Poser anisotropic node is
My Freebies
Buy stuff on RedBubble
ice-boy posted Sun, 15 March 2009 at 3:37 PM
IMO the anisotropic is bad in poser.it needs to be combined with some normal specular.
homeriscool posted Tue, 17 March 2009 at 4:10 PM
wow , thanks everyone. i wasnt quite expecting this much help and advice. thanks again !
