shareone opened this issue on Mar 16, 2009 · 19 posts
shareone posted Mon, 16 March 2009 at 1:38 AM
Hi,
I followed an IBL tutorial and noticed that Poser (7) IBL light using real hdr file turned the scene to be white (over burned for all contrast values I tried).
I then used a jpg that came with this hdr (circled image) and I got nice results (well, except strange stains in few places).
Question are, can Poser work with real hdr files?
If not, can I use any jpg or a circled hdr jpg required?
If yes, how can I convert hdr files to this jpg?
Thanks for your help.
Believable3D posted Mon, 16 March 2009 at 1:52 AM
Hm, not sure if regular Poser 7 supports HDR... I believe you need Poser Pro for that.
To convert, you'd obviously need an image editing program that can handle hdr. E.g. Photoshop. Then you can just save as jpeg or whatever.
______________
Hardware: AMD Ryzen 9 3900X/MSI MAG570 Tomahawk X570/Zotac Geforce GTX 1650 Super 4GB/32GB OLOy RAM
Software: Windows 10 Professional/Poser Pro 11/Photoshop/Postworkshop 3
By the way, did you try just turning all the intensities down on the lights to see what you got? That's where I would start.
______________
ghonma posted Mon, 16 March 2009 at 2:12 AM
To convert HDRs to other formats i would suggest either HDRShop or (better) picturenaut. Both are free:
ice-boy posted Mon, 16 March 2009 at 3:29 AM
poser 7 supports it.
Latexluv posted Mon, 16 March 2009 at 5:06 AM
Attached Link: http://sites.google.com/site/bagginsbill/free-stuff/genibl---ibl-generator
Yes, Poser 7 supports the use of HDRI. First off, I would highly suggest going to bagginsbill's page and getting both the Evosphere and the IBL Generator. Following his instructions and using the files he provides, you can make your own IBL and HDRI images for use in Poser."A lonely climber walks a tightrope to where dreams are born and never die!" - Billy Thorpe, song: Edge of Madness, album: East of Eden's Gate
Weapons of choice:
Latexluv posted Mon, 16 March 2009 at 5:15 AM
Here's the rendered image using the IBL.
Weapons of choice:
Latexluv posted Mon, 16 March 2009 at 5:17 AM
Weapons of choice:
Typically, I keep my HDRI set at 70%.
Weapons of choice:
ice-boy posted Mon, 16 March 2009 at 5:51 AM
can i ask you if you have shadows turned on the hair? it doesnt look like there are shadows but at the same time it doesnt look bad.
looks pretty good.
shareone posted Mon, 16 March 2009 at 6:32 AM
Thank you all for your help.
Believable3D, I changed intensity and still got white scene. BTW, I used only one IBL light.
ghonma, thanks for the links.
Latexluv, this link is great and I will use it, but take in mind it generates jpg, not hdr file.
ice-boy, I see now that the tutorial I took was indeed Poser Pro tutorial: poserpro.net/King_Tut/Lighting/poser_IBL.html
If Poser 7 can handle hdr files correctly, can you explain how?
Thanks again...
ice-boy posted Mon, 16 March 2009 at 7:51 AM
the same way like poser pro.
read every thread from bagginsbill about IBL,reflection,.....
Anthanasius posted Mon, 16 March 2009 at 11:42 AM
This time i'm learning and manipulating in all the way GC shader and now i use IBL or HDRI at 20-30% !
Miss Nancy posted Mon, 16 March 2009 at 12:03 PM
in case nobody already mentioned this, the use of a sharp-edged poser shadow in an hdri render may be intuitive, but is not in accord with the laws of optics IMVHO. the whole idea behind hdri is that it should provide the sole illumination in the scene, leading to soft AO shadows. however, in the absence of indirect lighting (by activation of the GIvariables using python script), hdri in FFRender is currently not up to specs as it is in more advanced renderers.
SSAfam1 posted Mon, 16 March 2009 at 2:12 PM
http://poserpro.net/King_Tut/Lighting/poser_IBL.html
^^^Regarding that tutorial---didn't BB say to plug the image_map into the intensity?
Latexluv posted Mon, 16 March 2009 at 3:52 PM
If you have Poser Pro you can use Bagginsbill's set up to create HDRI directly out of Poser. Sorry that I wasn't clear about that. If you have Poser 7, then you save out your jpg and then import into HDRShop and save out as a HDRI. I have also used Artizen HDR to save out as a HDRI.
Since the poster of this question is new to IBL and HDR in Poser, it seems to me that he may be unaware of one fact (without a demo render of his image, I'm guessing at this). IBL and HDRI in Poser is a diffuse light only. It has no specularity to it, so a second light must be added to your scene to handle this or else you will get a very flat, cartoony like render. My above examples were done with only two lights. One was the IBL/HDRI, the other was a spotlight pointed at V4's head. Turn the intensity of the HDRI light down to anywhere between 30% and 70%, and set the spotlight to say 50% to 70%.
SSAfam1, I have played with plugging the HDR into the intensity. This is if you want a white balancing effect to your final render.
Weapons of choice:
hborre posted Mon, 16 March 2009 at 4:07 PM
SSAfam1, Latexluv is correct about the IBL image_map plugged into intensity. It is just a white balance effect, and BB recommends setting the intensity to 200% optimally. It does work beautifully.
bagginsbill posted Mon, 16 March 2009 at 4:36 PM
Just a few quick notes. I'm overwhelmed with work so can't write my usual long answers.
SSAfam1 posted Mon, 16 March 2009 at 5:54 PM
