pappy411 opened this issue on Mar 23, 2009 · 9 posts
pappy411 posted Mon, 23 March 2009 at 4:49 PM
anyone know if Michael 3 and 4, also Victoria 3 and 4 numerical joint parameters can be printed out in their entirety and if so, where can they be obtained.
Pappy
markschum posted Tue, 24 March 2009 at 12:05 AM
Not sure what you mean but its all in the cr2 file .
EnglishBob posted Tue, 24 March 2009 at 5:21 AM
I derived the Poser Dork's endpoints some time ago, using text editor macros (I think I used Crimson Editor, or possibly Notepad++) for import into a spreadsheet. I can't remember the exact method, but shouldn't be too difficult to re-engineer it. If you're delving that deeply into joint parameters you probably have the required skills already. ;)
pappy411 posted Tue, 24 March 2009 at 10:25 AM
That is exactly what I was referring too Bob. I can do it manually but it is quite time consuming. when doing several figures. I was hoping someone knew of a script or shortcut method to do this.
Thanks
EnglishBob posted Tue, 24 March 2009 at 11:34 AM
As I remember it, it was a simple (if repetitive) matter of searching for text strings and copy-and-paste of the data that followed. Someone who was skilled in the art - i.e. not me - could probably knock up a Python script without much trouble. You could try posting a request in the Python forum, see if any of the gurus there have time on their hands.
Dare I ask why you want to do this? Print it out, even?!
markschum posted Tue, 24 March 2009 at 11:57 AM
I have a script that extracts the endpoints for a loaded figure if thats all you need . Its a python that puts out actor, parent, endpoint,center in a csv text file .
markschum posted Tue, 24 March 2009 at 1:12 PM
It was written when I was looking at trying to transfer rigging to another application.
This is a cutdown version supplying only the actor name, parent name , origin and endpoint.
The manual says endpoint of parent is the startpoint for the child.
You will need to modify the output filename , I use a folder c:temp as a workspace
The output may need a replace all ( with "" but thats easy in any editor.
pappy411 posted Tue, 24 March 2009 at 1:17 PM
Thank you Marckschum
EnglishBob posted Wed, 25 March 2009 at 5:00 AM
Thanks! This will be useful if I ever get back onto that project.
