Forum: Vue
Subject: Vue 6 Pro crashes after I import a Poser character. Why oh why?
Michaelab opened this issue on Mar 27, 2009 · 8 posts
Michaelab posted Fri, 27 March 2009 at 12:05 PM
I've got an interesting problem.
When I import a new character into Vue (6 Pro) from Poser 6 and then try to render it, Vue crashes - every time, and I do mean every time - so I always save it before I render.
And then I go through the ritual of starting Vue back up, bring up the recently saved Vue file and then render it and it goes fine.
I've read in previous posts about there being a corrupted Poser file, but it does not matter what Poser character I use, Vue still crashes, so if it is a corrupted file - and if so, how would I rememedy that reoccurring situation? - then all characters have a corrupted file.
Has anybody experienced the same thing?
And, does any one of the great Vue-Poser adepts out there know how to stop this annoying little habit that Vue has? It would sure save me a bunch of time if I could stop the crashing so fixing this problem would be GREATLY appreciated.
Thanks.
Michael
krickerd posted Fri, 27 March 2009 at 12:12 PM
What operating system do you have?  I am using Vista Home Premium and had a serious problem with crashes.  I was told to switch the options to run it in XP compatability mode.  Just doing this one thing has helped quite a bit.  It still occasionally crashes but not nearly as much.  I have exported from Daz Studio and imported and not had much of a problem.  Certainly NOT crashing every render attempt.  That's my 2 cents.  To get more help, I suspect you'll have to be more specific about your specs.
Michaelab posted Fri, 27 March 2009 at 12:30 PM
Thanks.
I run a PC Windows XP Professional. Service Pack 2
3GB of Ram,  Itnel Xeon CPU, 5120 @ 1.86Ghz
Nvidia Quadro FX 550 video card
AboranTouristCouncil posted Fri, 27 March 2009 at 4:48 PM
I had a similiar problem. Re-installing Vue worked and no problems since.. Here was my work around until I got frustrated enough to reload everything: Import Object into an empty scene, save object as .VOB.
...Insert some witty or thought provoking comment here...
ArtPearl posted Fri, 27 March 2009 at 6:48 PM
Attached Link: "I can see the sun" tutorial
Perhaps attenuating the light intensity would do the trick - Edit the light, in the lighting tab chose 'custom'  and edit the filter to have less intensity at the source so it doesnt wash out the whole scene but enough to light the subject. Artur demonstrates  it very clearly in his tutorial in the link above. (and the rest of his points are interesting to watch too)
"I paint that which comes from the imagination or from dreams, or from an unconscious drive. I photograph the things that I do not wish to paint, the things which already have an existence."
Man Ray, modernist painter
http://artpearl.redbubble.com/
AboranTouristCouncil posted Fri, 27 March 2009 at 8:41 PM
He makes it look so easy....
martial posted Sat, 28 March 2009 at 4:57 PM
No problen here with Vista home premium 64 bits
AboranTouristCouncil posted Sat, 28 March 2009 at 5:03 PM
Well, I didn't want to mention that i had that trouble when I was using XP. SInce I crossed to the dark side (Mac OS), I haven't had that problem since.
