Subject: Please help: cloth simulation fail message
NanetteTredoux opened this issue on Mar 28, 2009 · 6 posts
NanetteTredoux posted Sat, 28 March 2009 at 3:23 AM
I modelled a simple v-neck top for the G2 females using blender. I created material groups and exported it to an obj file. Poser did not see the material groups. So I tried exporting it to a 3ds file, and then the groups came in perfectly.
I loaded Olivia and the garment, positioned and scaled the garment, parented it to Olivia's hip, and entered the cloth room. I created a new simulation, clothified the top, set Olivia as the collision object, put a relaxed standing pose at frame 20, and calculated the simulation. All dynamic settings are at the defaults.The top does not intersect Olivia anywhere.
I get a message that it is calculating dynamics, and the almost immediately a message that "simulation failed at frame 0". I can't seem to get around this.
I would be so grateful for any help.
Poser 11 Pro, Windows 10
infinity10 posted Sat, 28 March 2009 at 4:41 AM
 You must save as prop first, then bring it into the scene a second time as a prop.  Then set up your simulation and run it.
To fix any further troubles, export the item as an OBJ after saving it as a prop.  The re-import it, and save as another prop.  Use the second prop for the simulation.
Poser is a bit of a fussy-wuss about these things.
shrugs
Eternal Hobbyist
NanetteTredoux posted Sat, 28 March 2009 at 8:37 AM
Thank you very much. I am going to try that right now.
NanetteTredoux posted Sat, 28 March 2009 at 9:09 AM
Unfortunately that does not work. I am beginning to wonder if there is something wrong with my mesh, but I have no idea what to look for. The mesh has no folds and doesn't touch itself anywhere. I fixed two little holes but that did not solve the problem either. I am at a loss - I may have to start over....
infinity10 posted Sat, 28 March 2009 at 9:49 AM
sorry to hear of it... please keep us posted if you do find the source of the problem, so we may learn from your experience.
thanks !
Eternal Hobbyist
markschum posted Sat, 28 March 2009 at 10:09 AM
try running the cloth itself in a simulation , that will test the cloth integrity, show unwelded parts as they fall off :)  and so on. It should not take very long with no collisions. If that fails there is a mesh problem to fix.
