Analog-X64 opened this issue on Mar 28, 2009 · 17 posts
Analog-X64 posted Sat, 28 March 2009 at 5:41 PM
FranOnTheEdge posted Sat, 28 March 2009 at 7:00 PM
Measure
your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Analog-X64 posted Sat, 28 March 2009 at 10:09 PM
That is the Step I was missing!!! :)
Analog-X64 posted Sat, 28 March 2009 at 10:52 PM
I dont know enough about mats, to achieve a plastic look, is it a combination of Light and Mat? or is it just how the Mat is tweaked?
Right now in the attached render I'm using "Flat White" from the Basic set.
Analog-X64 posted Sat, 28 March 2009 at 10:53 PM
dhama posted Sun, 29 March 2009 at 3:38 AM
If you take a plain mat and add a little 'reflection' to it, it should give you the look you are after. If you go to 'Objects' and then 'edit material', you'll find it near the bottom. Just move the slider about 10% to start with and see how it looks.
TheBryster posted Sun, 29 March 2009 at 4:37 AM Forum Moderator
*Terrain Editor - I suck.
*This is true - But I'm worse than you are. :lol:
Analog-X64 posted Sun, 29 March 2009 at 6:24 AM
dhama: that seems to be doing the trick with the plastic look. :)
TheBryster: Oh Common!!! You are the master from Mars. :)
Now because this is done in the terrain editor, I'm guessing that is why I'm getting that "sedimentary" look on the sides?
I went into the Terrain Editor and clicked on Smoothing a couple of times and that seems to get rid of the stretch marks on the sides, but not completly. Is there another way of doing this?
TheBryster posted Sun, 29 March 2009 at 6:52 AM Forum Moderator
It does take a lot of practise to get this right. I'd go along the experimental route. Try before you buy.
Analog-X64 posted Sun, 29 March 2009 at 7:08 AM
Quote - It does take a lot of practise to get this right. I'd go along the experimental route. Try before you buy.
Yup.. that is what I'm doing :)
What has me scratching my head, is a simple Boolean operation.
I created a cube and stretched it, I than imported a text as obj. I made the Cube the Positive and the Text as Negative. I grouped them together and renderd, in the hopes that the text would be carved out of the cube. No such luck. Is this a known issue when importing an OBJ vs using a build in primitive?
Analog-X64 posted Sun, 29 March 2009 at 7:26 AM
Ok so I found Brycetechs tut on Boolean with Imported objects, which now makes sense :)
All these elements, I'm working on will come together in Photoshop to make a Concert Backstage Pass type of thing.
I will post the end result here. :)
FranOnTheEdge posted Sun, 29 March 2009 at 8:33 AM
Ho! Looks like you've been working through the night (or maybe 'day') while I was rendering, and trying to sleep to the hum...
:m_sleepy:
Sounds like an interesting thing you're making, I look forward to seeing the result.
Measure
your mind's height
dhama posted Sun, 29 March 2009 at 10:22 AM
Just remember when saving the height map, that it's 16bit greyscale (not RGB) That should make it smoother.
Analog-X64 posted Sun, 29 March 2009 at 12:19 PM
Quote - Just remember when saving the height map, that it's 16bit greyscale (not RGB) That should make it smoother.
Yes, I made that mistake the first time around so I had to go back and re-do it.
And yes, I havent had much sleep this weekend. I think I've only slept 4 hours or so.
Trying to figure out how to Make Booleans work on Imported objects in Bryce at 2:00AM...Not Fun.
TheBryster posted Sun, 29 March 2009 at 1:55 PM Forum Moderator
Simple. Make object Solid.
Gotta love booleans! Hats-off to you for trying them out.
Analog-X64 posted Sun, 29 March 2009 at 2:23 PM
Yeah.. So first I had to import the Object and "Ungroup" once that was done, I used the E Button to make object solid. I had to Change the attributes to Negative. Than I had to Select my Cube and change that into Positive. Once that was all done, Select them all group again and render :) Phew!!!
TheBryster posted Mon, 30 March 2009 at 9:10 AM Forum Moderator
Ah! Grasshopper! You're well on the way to becoming a Boolean Master!
