LunaFaye opened this issue on Apr 07, 2009 · 6 posts
LunaFaye posted Tue, 07 April 2009 at 11:07 AM
I'm having trouble with assigning material names. When I exported my obj, the material zones were named correctly. When I imported the onj and set it up as a figure, they were not. So I went into the cr2 and obj files in a file editor. I changed all the mat numers to the correct names. Still in Poser they are showing up with just the material number. Material_57 for example. Now I've searched both the cr2 and the obj and there is NO string for "Material_57", yet there it is in Poser. >:(
I've tried re-loading the figure dozens of times, and even tried restarting Poser a couple of times. Still that stupid Material_57 is there. I don't know what else to do to get rid of it.
Any ideas or suggestions would be VERY welcome!
Luna
BAR-CODE posted Tue, 07 April 2009 at 11:10 AM
Looks like a 3DMAX material .. is keep poping up ..
Only to be fixed in MAX if thats the case
IF YOU WANT TO CONTACT BAR-CODE SENT A PM to 26FAHRENHEIT "same person"
Chris
LunaFaye posted Tue, 07 April 2009 at 11:12 AM
Except it's doing it with ALL the materials. :(
Material_55
Material_56
Material_57
etc...
I did make the obj in Max. Wouldn't that still show up in the ojb file though?
(Next option was to go into Max to re-export it.)
Luna
BAR-CODE posted Tue, 07 April 2009 at 11:15 AM
Quote - Except it's doing it with ALL the materials. :(
Material_55
Material_56
Material_57
etc...I did make the obj in Max. Wouldn't that still show up in the ojb file though?
Luna
You have to rename in MAX and be sure to export the new names ..
Otherwise you keep getting the MAX "names" best to rename while making things ..
Chris
LunaFaye posted Tue, 07 April 2009 at 11:27 AM
I got the solution!
In case anyone else has simmilar problems:
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2768443&page=1
Luna
pauljs75 posted Tue, 07 April 2009 at 5:19 PM
Lemme guess, the .mtl file that is supposed to tag along with the .obj? (Which should be viewable in a text editor.) Of course some software gets funny if that part is missing.
