MikeJ opened this issue on Apr 11, 2009 · 5 posts
MikeJ posted Sat, 11 April 2009 at 3:51 PM
In the Material Room for the Image Node there are dials for U offset and V offset. I'm wondering if this means that Poser can use models with UV maps that are outside the typical 0-1 range.
If so, if for example a group of UV islands were in the 0 to -1 (that's zero to negative 1) range, then I assume the U offset would be -1? For an object that had UVs for certain materials in that range, that is. And so on for the U offset and into the other possible ranges.
I don't really have time to test it out, just wondering if anyone knows offhand. It could make a difference for as far as some things I want to do with Poser.
