Forum: Blender
Subject: Rendering Problem
keppel opened this issue on Apr 12, 2009 · 5 posts
keppel posted Sun, 12 April 2009 at 6:41 AM
I've been working through the Captain Blender tutorial in the "Introducing Character Animation with Blender Book" and have hit a road block at the eyelashes.  The picture below shows the problem.  Top picture is the render of just the eye lashes.  At this point they render as they should, with the transparency working perfectly.  When the eye lashes are in position with the mesh of the head I get this strange block of solid colour where the eye lash mesh and head mesh touch.  If I move the eye lashes a short distance away from the head mesh they render properly again.  Can anyone tell me why this might be occuring?
Render Question
My Renderosity Store
Virtual Furnishing
My Portfolio
Reddog9 posted Sun, 12 April 2009 at 8:26 AM
Off the top of my head...
  1.    looks like your using Ambient Occlusion?  .. as far as I know.. Ambient Occlusion doesn't render transparent shadows.
2.  Does the material for the Face/Eyelashes have Transparent Shadows selected.  It's a button in the material setting for each material which tells blender that it should receive a transparent shadow.
3.  You may need to increase the Ray Depth.  I believe it's set pretty low by default.  You may be getting a shadow from one eyelash through it's fold to the other side.. but then not through it again.  It should be under the render settings.
My best guess would be the fact that it's the ambient Occlusion issue.
Check these:
http://www.blender.org/forum/viewtopic.php?t=13328&sid=33e32cb7c5ab8ef5ec014578f9847fd9
http://blenderartists.org/forum/showthread.php?t=150949
http://www.blender.org/forum/viewtopic.php?t=11500&view=previous&sid=6a875fcba385ac850d5362c5fd813bfc
Good luck,
Scott
Reddog9
Tutorials, Samples and Models
www.blender3dclub.com
l3la posted Sun, 12 April 2009 at 8:48 AM
Make sure you have activated "TraShado" (Transparent shadows - shadows take into account the alpha map) for the material of the face - on which the shadows fall. This button is on the shaders tab of the material buttons window.
keppel posted Sun, 12 April 2009 at 9:42 AM
Reddog9 & l3la
AO is not being used, however I selected Transparent Shadows as you both suggested and that fixed the problem.  Thanks for your help
Shane
Virtual Furnishing
My Portfolio
yantram3d posted Mon, 13 April 2009 at 12:42 AM
Attached Link: 3d Animation & Rendering Studio
**Hello, Reddog9 is Right. try to Follow** **Reddog9** **Instruction.
Thanks & Regards,
3d Animation Studio
