krickerd opened this issue on Apr 13, 2009 · 4 posts
krickerd posted Mon, 13 April 2009 at 5:47 PM
I have an underwater scene that renders fine on "final" setting at lower resolutions but faults out with an out of memory error or crashes when rendering at higher ones. It is > 200 million polygons. I don't think it's the number of objects though. I believe it is either the fact that I'm using:
Maybe #2? Do texture maps eat up more RAM at higher resolution renders? I could take this out and use procedural no problem. The maps aren't critical to the scene, especially the foreground terrain which is mostly covered by seaweed.
Xpleet posted Mon, 13 April 2009 at 6:05 PM
Displacement mapping. It's virtually useless on a 32 bit platform. Even though 32bit can have 4 gigabytes of RAM, Windows XP 32 is only able to allocate 1,2gigabyte per allocation. Exceeding that limit, the application will crash. Forget about the 3gigabyte switch, that is but a dream.
I've had a displacement of pebbles for a couple of hundred meters (quality +2) in Vue7 x64 with 4 gigabyte of RAM and the commit charge spiked to 7000 (extending the page file) in a matter of seconds.
ArtPearl posted Mon, 13 April 2009 at 6:40 PM
Attached Link: Displacements&crashes
Some severe problems associated with the use of displacements were discussed in the linked thread, maybe others too. I seem to remember that lowering the quality on the displacements helped."I paint that which comes from the imagination or from dreams,
or from an unconscious drive. I photograph the things that I do not
wish to paint, the things which already have an
existence."
Man Ray, modernist painter
http://artpearl.redbubble.com/
krickerd posted Mon, 13 April 2009 at 9:54 PM
Okay so I tested it by process of elimination. Displacement is causing NO problem on my system. But by eliminating the bitmapped images on the terrains, the render went from not working at all (or crashing after 20%) to rendering the image in 20 min at 1440 X 900. My CPU meter showed the RAM never got much above 40% and the CPU useage stayed at 100% for each of the 4 cores. I did reduce the quality of the displacement to -3 (which is fine for what I'm doing). I may re-render with the other spheres in displacement (since the bumpmapping is leaving some bad moire patterns). I also need to make my cones holding the fish ecosystem COMPLETELY unseen or delete them while keeping the fish.
