offrench opened this issue on May 07, 2009 · 4 posts
offrench posted Thu, 07 May 2009 at 1:04 AM
I am trying to make renders of solar system planets, using realistic scales for them.
I have made Jupiter and its 4 main satellites. I have the right sizes for all of them but would like the distance between the satellites and Jupiter to be exact also.
Is there a way to lock the distance between two objects? I want to be able to move the satellites, but make sure they always stay on their orbit.
I have tried the track or link options, but they do not lock the distance between both objects (unless there is an option I did not see).
Fantasy pictures,
free 3d models, 3d tutorials
and
seamless textures on Virtual Lands.
AVANZ posted Thu, 07 May 2009 at 2:03 AM
If you are creating an animation you should use "linked" and only move Jupiter around. On top of that you can "Lock" objects in the viewports by clicking on the symbol underneath the "Load Material" icon in the object properties panel and choose "Locked". Another nice one you'll find there is "Main view only". It frees the other viewports of cluttering.
If you first select a moon in the world browser it is still possible to move it.
Arraxxon posted Fri, 15 May 2009 at 10:29 PM
offrench - you can do the following:
Hope this will help ...
Arraxxon posted Fri, 15 May 2009 at 10:48 PM
Just to add - now after adjusting the pivot point, you can link the satellite to Jupiter - so this complements your system.
Linked you can move Jupiter and the satellites follow, still always being able to rotate them separate around Jupiter on their exact orbit ...
