galactron22 opened this issue on May 15, 2009 · 4 posts
galactron22 posted Fri, 15 May 2009 at 10:03 AM
I found a file that I want to use in a Poser render but it's a 3ds .max file, is therea way to import this into Poser 7?
Any help with this will be appreciated.
Ask me a question, and I'll give you an answer.
CaptainJack1 posted Fri, 15 May 2009 at 10:18 AM
There's not really a way to import it into anything, actually... that format is so proprietary that it's scary. AFAIK, the only thing you can do is open the file in 3D Studio, then export (at least parts of it) in some more portable format. If you don't have 3D Studio or know someone who does, you probably won't be able to do anything with it, I'm afraid.
You could try getting the evaluation edition of 3DS, but I'm not sure what it's export options are.
wheatpenny posted Fri, 15 May 2009 at 10:21 AM Site Admin
The 3dsMax demo is fully featured, so you can use it to export your max file as either obj or 3ds.
Jeff
Renderosity Senior Moderator
Hablo español
Ich spreche Deutsch
Je parle français
Mi parolas Esperanton. Ĉu vi?
galactron22 posted Fri, 15 May 2009 at 10:46 AM
Thanks for the info gentlemen, I'll give this a try right away.
