slonishko opened this issue on May 15, 2009 · 6 posts
slonishko posted Fri, 15 May 2009 at 2:35 PM
DS will not see my content, it is one of these 2 problems. Can anyone verify which it may be ?
I have my Runtime folder on my D: drive, not my C: drive, it sees it when i do a scan, but will not load it. the apply button is greyed (unclickable)
This is the newest (yesterday) version of DS 2.3
RHaseltine posted Fri, 15 May 2009 at 4:25 PM
I don't have the latest 2.3, but with DS installed outside the Program Files folder I've had no toruble accessing content folders on different drives under the Beta and now the RC of Widnows 7 (and with the beta of DS 3 it works with the application installed to Program Files). Was it working with previous versions of DS? Are you trying to select the folder through Edit>Preferences>Directories?
animajikgraphics posted Fri, 15 May 2009 at 5:19 PM
You can alternatively load content with FILE->IMPORT load the cr2 in any runtime (RUNTIME/LIBRARY/CHARCTER or RUNTIME/LIBRARY/PROPS (any drive).
I use this method all the time to load content.
FatCatAlley.net | Now Playing "SpaceCat 5" Parts 1 and 2
animajikgraphics posted Fri, 15 May 2009 at 5:21 PM
You can also Add additional runtime to D|S by going to Preferenrce and adding each Runtime folder there. Once dibe you should be go to go. I prefer the manual File -> Import method, but that's me.
slonishko posted Sat, 16 May 2009 at 1:17 AM
I got it figured out. I dont know what happened, but it managed to fix itself in the night :D
Now I am mostly happy again thanks for the help everyone :D
renmmk posted Fri, 22 May 2009 at 11:14 PM
ok...well...you knew you woupld have problems when you upgraded right?
