Forum Moderators: wheatpenny Forum Coordinators: Anim8dtoon
Photography F.A.Q (Last Updated: 2024 Nov 26 6:56 am)
are you using a card reader or straight from the camera?
can you see the images on your camera?
How does the camera show up on your computer? as another drive?
Check the cable..
www.bclaytonphoto.com
bclaytonphoto
on Facebook
Attached Link: SD / SDHC Memory Card Reader
is your SD card one of the new SDHC cards? If so you need special adapters for them to be read.ecurb - The Devil
If this is the same type of card you normally use..I'm not sure..
When your window opens...
close that
then go to "my computer"
try going to it from that direction..
Can you please post the exact card reader you have?
Do you have a cable to connect your camera to the computer? maybe you could try that
The PC may need to be restarted in some cases..
bclaytonphoto
on Facebook
There are a couple of models..
http://www.walmart.com/catalog/product.do?product_id=9722059
http://www.walmart.com/catalog/product.do?product_id=10038332&findingMethod=rr
http://www.walmart.com/catalog/product.do?product_id=9722060&findingMethod=rr
If you have the first one..(a multi card reader) You should see several drives when you have it hooked up.
At least, that's the way mine does on Windows XP
The other ones, I'm thinking it will show up as a single drive.
The fact that you can see the image while the card is in the camera, tells me, the card is mostly likely OK, and there seems to be an issue elsewhere
Try this..
Take a different card (assuming you have one) take a few shots and see if you can view that from the computer
bclaytonphoto
on Facebook
I was on vacation and bought a new SD card for my camera (Fuji S700). I can't get it to upload to my computer, tried locking and unlocking it. Anyone got any suggestions? Thanks.
