Subject: Trans maps question
meltz opened this issue on May 16, 2009 · 4 posts
meltz posted Sat, 16 May 2009 at 2:33 PM
OK so what  i am tring to do is make an outfit on M4 with the body suit. Now that suit has to have a yin and yang on the chest, but one side of the yin yang has to be "cut out" showing his chest. Can i achieve this with a trans map? If so any info how to make one?
hborre posted Sat, 16 May 2009 at 3:13 PM
Here is a link to one of several tutorials.
http://www.ebonshire.net/tut-posb/p-trans-easy.php
Just google 'transparency maps for poser' and you will find other links.
dlfurman posted Sat, 16 May 2009 at 3:14 PM
Yes. This is how I would do it.
In your photoediting program load your texture for the body suit. This is for the placement of the symbol.
Make a new layer fill it with 100% black. This will be your Trans map layer. 100% black is transparent, 100% white is visible. Change the opacity so you can see the bodysuit texture beneath.
Load your symbol in a new layer.  Make sure what you want to be invisible is 100% black and the other is 100% white. If you need to you can invert this layer. Scale and place as needed.
Make sure your symbol layer and transparency layers are 100% opacity, Merge these two, save it out. Apply.
Intel Core i7 920, 24GB RAM, GeForce GTX 1050 4GB video, 6TB HDD space
meltz posted Sat, 16 May 2009 at 4:51 PM
awesome thanks for the info, gonna try and do it sometime soon. You guys rock
